Help with Playback Skips-Cubase LE4 Tascam US-144
Ok, I hope this is in the right place. Sorry guys its my first post.
![]() I'm having problems with my playback. It tends to skip sometimes during playback, but the skips are not there when I export it and listen to it. The skips are bad, and make me lose my timing or rhythm if Im recording something else. It usually happens when I record 3 or more tracks. The weird thing is, I had 4 tracks and it didnt skip, I open it up the following day erase one of the tracks to re-record it, and BAM skips galore. okay, My set-up: HP dv6707us 2GB RAM 2 GHz Processor AMD 64 AthlonX2 Tascam US-144 and Cubase LE4 All effects are pre tascam so go in directly, and it is currently 4 audio channels, and Addictive drums on another channel. A total of 5. What do oyu guys think?!? Thanks in advance. |
Skips, cracks, pops etc. are indicative of system interrupts caused by using the same drive for your programming and music data. The easiest thing to do is get another drive and dedicate it to your data only.
As in an External Hard Drive?!? I thought it was a RAM or sound
card problem. Okay, so if I get ANY size Hard Drive, and save all my Cubase Recordings and anything I use for recording it will work??? Also, what would you suggest saving in the External HD? Im a little new to this, and appreciate all your help. |
Another internal hard drive would be good and they're pretty cheap these days. If your using you workstation for web surfing then you may want to get the spyware off it and check for viruses especially if this problem just creeped up on you.
you want to use the extra hard drive for just your audio files.
Ok, sorry if I sound like a jackass, but your suggesting me to put
another internal hard drive. On the internal hard drive, I would install all my music production stuff (Cubase, VST's, MIDI, etc.), and run all the software off of there instead of my original hard drive?!? ![]() Am I on the right track, or completely out of it?!? So, the playback is skipping due to the hard drive running my Cubase, & all of a sudden trying to run something else causing it to overload and skip??? I hope I got that right. Also, I notice on the VST performance, the ASIO marker sometimes shoots all the way up. What does that mean? Thanks in advance. |
The asio part of VST performance window indicates the resources left to calculate the ASIO block and forward it to the audio driver in time. Try increasing your latency to increase the time available.
WOW
your good!!! I really appreciate everything.Now, increasing the latency, wouldn't that mess me up when recording? Or, it's not that much of a delay to actually mess me up? (as far as timing and rhythm is concerned) I appreciate everything you have answered. |
| Delays and Skips in PLAYBACK | thehorseshoe | Cubase User Forum | 0 | 07-08-2002 00:58 |
| Skips in Playback -- Soundcard issue??? | gmiller1122 | Digital Recording & Computers | 7 | 05-27-2002 08:52 |
| Cubase skips? | MartyMcFly | Digital Recording & Computers | 2 | 05-25-2002 13:48 |
