Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 02-26-2009
Zeekle Zeekle is offline
Junior Member
Zeekle is on a distinguished road
Recording more that one MIDI channel at a time
Hi all
The title says it all really.
Can anyone tell me if its possible to record MIDI data to more than one channel at a time.
Such things as vol, pan etc
I'm using Cubase VST. The MIDI data is to help automate my mixes on my Digital recorder. At present I am recording one channel at a time.
All replies gratefully received
Zeek
Old 03-03-2009
Dredakyst Dredakyst is offline
Newbie
Dredakyst is on a distinguished road
Originally Posted by Zeekle View Post
Hi all
Zeek
Hmm... its been a while since I've used Cubase VST, but you should be able to record all 16 midi tracks into one track into cubase then go to "Dissolve Parts" and it will split everything out for you.
Rename the tracks and volia.
Old 03-03-2009
Junior Member
Cheers for that - I thought I'd just asked the dumbest question ever. I appreciate the VST is an old version but it does what I need so no need to change.
I thought I might try to use a Korg Nano Kontrol to go into Cubase and record the vol / pan part of the mix as I automate, but its only worth it if I can do more than one channel at a time - otherwise I'll just continue doing as I have been, one channel at a time.
Once again, my humble thanks
Zeek
Old 03-03-2009
Newbie
No prob...
yea midi comes up to 16 channels... so I would just record your whole track into cubase the dissolve parts and then you'll have to match up the parts with the channel... from there you'll have everything laid out for you...
as for using the Nano.. as long as Cubase recognizes it, you should be solid and it will serve as your external midi mixer. I would have to read up on how you assign channels and etc but i know you can...
Old 03-04-2009
Junior Member
Smile
Cheers Dred,
I'll give it a whirl and see what happens. you have definately shed some light on my automation wishlist.
Many thanks
Zeek
midi channel settings lopie Cakewalk / Sonar Forum 1 12-19-2004 15:12
MIDI Recording DR-770 Matching to Time Signature LewKellogg Roland, Boss, VS Series Forum 2 07-28-2004 16:08
midiman 4x4 via USB sees only one channel at a time dick west Digital Recording & Computers 3 01-04-2004 12:17
Send a note from a channel aftertouch in real time SergeD Cakewalk / Sonar Forum 5 05-16-2003 07:52
Recording Midi and Audio at Same time? kelitupu Digital Recording & Computers 3 04-25-2002 17:06
