Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 02-20-2009
pezking pezking is offline
Force of Nature
pezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond repute
JCM900 Boost?
I've got a JCM900 100w Head, I play in a 6 piece band, and require a boost on my distortion channel for when I solo...
Ideally I just want to increase the volume of my distortion channel when I solo, as I like the tone, but there's no provision for it.
The only alternative I can think of is to buy a distortion pedal (which I've never liked compared to the Marshall) and use it on the clean channel.
Trouble with that is:
1. Costs money!
2. I would need to press two footswitches to get there
3. I like the sound of my amp currently.
Anyone got any ideas of what I could do? I tried out the TSL100 a few weeks ago, and I nearly bought it, but I thought my JCM900 sounded so much better!
Old 02-20-2009
Tadpui Tadpui is offline
Force of Nature
Tadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond reputeTadpui has a reputation beyond repute
I would suggest either an overdrive pedal or a clean boost pedal. They both do similar things, but an overdrive pedal generally adds a drive knob that lets you get more sensitivity and saturation without necessarily adding more distortion. Either way, they both boost your input signal and drive your amp harder without making big changes to your amp's distortion. I've never been a big fan of running a distortion/overdrive pedal through an amp's clean channel. I prefer to let the overdrive suppliment the amp's distortion.
Aside from that, I like to use my Boss CS3 compressor/sustainer pedal like a boost. Turn up the sustain and the level and I end up with a much more sensitive and louder signal that's perfect for soloing.
________________________________________________________________
Everyone's a voyeur, they're watching me watch them watch me right now
Old 02-20-2009
DrewPeterson7's Avatar
DrewPeterson7 DrewPeterson7 is offline
1K Silver Member
DrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond reputeDrewPeterson7 has a reputation beyond repute
There's not much you CAN do to boost the output for a solo - you can use a clean boost or an OD pedal, true, but if you use one to get some extra juice going into the amp, and the preamp is already in distortion, all that's going to translate to is more gain, not more level.
If you're considering selling the amp for a TSL100, maybe give a Mesa Stiletto Series II a look? It's their take on the "Marshall" sound, and while it's more modern marshall than vintage marshalle (think Bogner Exctacy), a few of the modes will probably get you where you want to be.
It's only a two channel amp, but Mesa adds a second volume control for a "solo boost" for a lot of their amps. The idea is, you're playing through the same channel, but with the click of a button you add a variable amount of power amp clean boost, so that your preamp tone is the same and it's just like your master was a couple notches higher. They've been doing this on the Rectifiers for years, and it's pretty awesome - it'll allow you to dial in just enough extra volume for your solos to poke out of the mix, without killing anyone on stage the rest of the time. And, as it's really a second master volume control, that boost can go anywhere from a db or two up to pretty much full poweramp volume.
Alternately, on the cheap, try grabbing a footswitchable EQ. You won't be able to get any added volume out of it, really, but you may be able to "shape" the tone in such a way that it cuts through the mix better, and seems louder.
Likewise, on the "perceived output" tack, try using an OD for your [/i]rhythm[/i] tone, and bypass it for your lead. As the more saturated an amp is, the more the dynamics in your playing compress, it's possible to dial your amp gain and OD gain such that you have a thick, compressed, saturated rhythm tone, but when you bypass the OD the preamp gain alone is a lot less saturated so your dynamic response is more explosive. I actually tend to do this myself, I'll use a TS9 into my Recto for heavy rhythm (set as a clean boost), but generally I'll bypass it whenever I solo so the amp's naturally more "open" and "explosive" gain lets notes jump out a little more.
"They can kill you, but the legalities of eating you are a little dicier." - David Foster Wallace
Old 02-20-2009
Guitarer Guitarer is offline
Custom User Title
Guitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond repute
Put a clean boost in the effects loop.
I've got an MXR Micro Amp in mine and it works perfectly. It's like $70.
Old 02-20-2009
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
The effects loop is your friend here. I always used to cut my rythmm channel with an EQ pedal, and turn it off for solos. The advantage here was that by putting a little mid-cut on the pedal, I got a volume and mid boost for the solos. A smaller increase in volume, accompanied by a mid-boost, wil cut better than either alone, and won't increase the overall loudness in the room as much. Just adjust your sound with the EQ on, you should be able to keep your basic tone the same for rythmms.
Old 02-20-2009
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Get an EQ pedal... lower the higher freqs and boost the mid-highs. You'll cut through with that real well.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 02-20-2009
ocnor's Avatar
ocnor ocnor is offline
Lord Of The Thighs
ocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond reputeocnor has a reputation beyond repute
+1 That really is the best way to do it.
Old 02-20-2009
Force of Nature
I guess I tend to play with a slight crunch as my main tone. That leaves enough headroom that when I turn on my overdrive, it does give me more output volume. If you play with more distortion for your main rhythm tone, then yes all you'll get is more saturation and not more volume. But my TS9 adds more mids to my tone so even then, it cuts through more.
Old 02-20-2009
Force of Nature
That does sound like a great idea actually.
I have two GEQ pedals around somewhere... Maybe I should resurrect them!
Thanks for the advice guys, I'll give it a go and see where I get.
Old 02-20-2009
Force of Nature
OK So I tried it, and it almost provides the results I'm after!
Because it's a Boss GE6 I have (no overall level) I couldn't just boost/cut across the board, instead I had to boost or cut each frequency.
The good news is that it worked, and I now have a clear idea of what I need to do - either A) Build a clean boost pedal to put in the loop or B) Build a pedal with nothing more than a volume knob and a switch in!
Thanks for your help.
Old 02-20-2009
mikeyc mikeyc is offline
Newbie
mikeyc is on a distinguished road
i've been using this setup for near 10 years on my JCM900. i does exactly what you are wanting.
  #12
Old 02-24-2009
mcmetal mcmetal is offline
Senior Member
mcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond reputemcmetal has a reputation beyond repute
don't know if dod still makes them but i have a bi-fet preamp pedal that i used a lot in the past.it just has a volume and a tone knob.nice thing is i can eq it up to add a little more high or lows and either boost or reduce my volume.i ran it alongside a delay pedal,through the effects loop,and would kick them both on at the same time.
  #13
Old 02-24-2009
Force of Nature
Option B is what a clean boost pedal is: a pedal with just a gain knob and a switch. You could use any pedal with a gain/level knob and just turn down any other effects on the pedal. Most overdrive pedals can double as a clean boost since you can turn the drive down all the way and turn the level up.
  #14
Old 02-25-2009
Force of Nature
No my option B would be purely just a pot in series with the signal, merely providing attenuation.
I've instead decided to build a replica of the MXR Micro Amp. They sell for £75. I will build my replica for £18. Anyone want one made?
  #15
Old 02-25-2009
iownrocknroll iownrocknroll is offline
Dedicated Member
iownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond repute
Whatever you do has to be in the effects loop for this amp otherwise distortion will increase.
  #16
Old 02-25-2009
Force of Nature
Bingo.
I hadn't realised until recently that the FX loop is between pre and power amp.
I need to service my amp at some point, the FX Loop level knob is a bit crackly.
  #17
Old 02-25-2009
owwmyfoot owwmyfoot is offline
slave to the grind
owwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond reputeowwmyfoot has a reputation beyond repute
Bingo.
Hey I have had success fixing crackly pots on amps with contact cleaner. Just spray (using the straw extension included with most quality brands) directing the stream into the inside of the pot while turning the knob on the outside. This usually clears up my issues. I'm a big fan of the jcm 900s, is yours a 4100? Does it have 5881 output tubes or is it a sl-x with the el-34s. I have played these many times and love the added gain, despite it coming from diode-clipping and NOT true successive gain stages (except for on the slx). Big fan I am
  #18
Old 02-26-2009
Force of Nature
Yeah that's something I keep meaning to sort out.
I think it's the 4100, but as for valves, I really don't know. I'll let you know when I clean that pot!
  #19
Old 02-28-2009
Minion Minion is offline
1K Silver Member
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
In one of my guitars I have a little clean boost pre amp that I built into it that has a 3 way toggle switch to set different gain levels...when I want to go into solo mode I just flick the switch and it adds a nice signal boost which also helps the overdrive by overdriveing the tubes more.....
Cheers
M-Audio Delta 44 + Delta 1010LT
5 Piece Drum Kit w6 Cymbals
Custom Made Bass Guitar
Custom Made Les Paul Guitar
Mackie Traction Studio 2.1
P-4 PC w 512mb DDR 80gb HD
Sell you used Equipment Here:
http://www.proaux.com/phpprobid/index.php
  #20
Old 03-01-2009
Force of Nature
Cheers
Fair enough, but that wouldn't achieve what I'm after. I really need a boost in level not drive, plus it's not unusual for me to use 2 or 3 guitars during a set so I need a pedal solution .
I'll post up the pics of my pedal build when I'm done.
JCM900 - Pros and Cons here ido1957 Guitars and Basses 5 07-23-2007 16:17
Mic on JCM900 musical5 Microphones 16 05-31-2006 16:40
jcm900 with EL34 Ostia Man Guitars and Basses 1 01-23-2006 18:16
Marshall JCM900 Reverb outlawtorn86 Guitars and Basses 5 11-15-2003 19:35
Marshall Jcm900 SLX Octaver Guitars and Basses 2 12-04-2000 15:01
