16 bits or 24 bits?
Can one of the crew tell me if it "really" makes any difference doing a CD on 24 bits?For some reason, I may not have tried using the 24 bits. Once I may have remembered that the 24 bits "won't burn" a CD. [Using my AW1600] I get pretty clean sounds from the 16 sounds. But, I always like to ask when I like the information and learn. Hope the golf season starts moving in THIS directions soon. Thanks, Green Hornet ![]()
THE GREEN HORNET |
I presume you mean tracking, but ultimately going to cd.
16 does work fine, the cool thing with 24 is you can come in nice and clean with 20db below full scale of headroom and still have conversion error noise well below you mic or room noise.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology Last edited by mixsit; 02-16-2009 at 17:06.. Reason: that's tracking not tacking' |
Yeh, it makes a difference. At 24bit, you're CD won't play in most commercial CD players!
There are 10 types of people...those who understand binary and those who don't My humble home studio! My Choons My DIY Broadband absorbers thread! Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack |
Yo "MIX" and "M. D."THANKS! Since my CDs from the 1600 Yam won't "play" in most CDs, like my car or home Sony player, I guess I'll have to do 16 bits. Some great music MD. So much talent. Appreciate your help. Green Hornet
THE GREEN HORNET |
If you're tracking, 24 bits will get you higher headroom, and if you ever feel like burning to a DVD-Audio disc, you'll be able to at higher resolution (although it's likely you won't be able to tell a difference if you belong on this Home Recording forum!).
However, as you've been told, the Red Book CD audio standard is at 16 bits, 14.4khz: anything else won't play correctly.
www.myspace.com/ironthrones - my sweet metal band www.myspace.com/stevehenningsgard - my recordings |
Just in case- You do know the normal route is track and process (mix) at the higher depth, then reduce to 16 for the cd?
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
i like 8 bits but im an odd ball
I refuse to be the nice guy. Do you want to get better or have everyone tell you you're awesome? |
16-bit: Around 65,000 points of resolution, dither noise on each individual track.
24-bit: Around 16.7 million possible points, 48dB more downward headroom (*DOWNWARD* headroom - "foot room" if you will), no dither noise, dynamic range far beyond almost any piece of gear imaginable. Always work in 24-bit until the last possible stage. |
^listen to this guy...
track, mix, and master at 24...then chop the files down to 16-bit at the end of the whole deal |
Not to disagree with you guys, because I don't disagree with you. I also record in 24bit until the last possible stage.
But I think Ethan Winter (or someone else like him that knows a lot more about recording than I do) insists that there is absolutely no difference between 16bit and 24bit. I'm pretty sure he did some experiments and has numbers to back that up. Just throwing that into the argument. Hopefully Ethan (or whoever it is) will come in and explain their theory. |
#12
Bottom line: The only "downside" to working in 24 bit is a 50% increase in file size from somewhat less than 700KB per minute to approx 1MB per minute of audio track. That's a small cost to pay for the 50% increase in digital canvas space. G. |
#13
Not that I'd want to argue with Ethan about anything either - But I think his point is with "file A" and "file B" -- One is 16 bit, one is 24, can you hear the difference?
I'm sure few could hear the difference. This is about stacking (perhaps dozens of) tracks together - Put 20 tracks at 16-bit (adding all that dither noise together) and you'll notice it. GRANTED: It's still going to be less than tape noise and the DAW is probably going to be throwing calculations in 32-bit FP no matter what the word length of the source files. Add self-noise of gear and what not into the equation and you're "eliminating excuses" by recording in 24-bit. But IMO, well worth the additional horsepower. |
#14
Plus the associated CPU power that is required to drive a 24 bits signal chain.
www.Waffleness.co.uk |
#15
G. |
#16
Ah fuck hah, I went dyslexic and nostalgic at the same time! (Thinking about modems apparently).
44.1 it is! ![]()
#17
![]() Seriously, if I were recording a classical music concert I'd definitely record at 24 bits. No matter how loud an orchestra (or jazz band etc) plays during rehearsal, they always play louder when the red light is on. So using 24 bits lets you aim for peaks around -15 or even -20, then you can normalize later to full scale with no degradation. All that said, I absolutely stand by my contention that for a delivery medium 16 bits is plenty. Nobody can ever tell the difference in a blind test. Same for high sample rates. This article from Mix magazine describes an extensive test where hi-res material was reduced to 44/16 and nobody could tell the difference: http://mixonline.com/recording/mixin...ing/index.html Again, this is for a delivery medium. --Ethan
The acoustic treatment experts |
#18
![]() Quote:
![]() --Ethan
#19
The part that I really didn't want to argue with was summed up in the delivery medium - I'm with you there - If you can't deliver and absolutely stunning recording in 16-bits, jumping to 24-bits wouldn't do diddly (just as if stunning recordings couldn't be made in 44.1kHz, then jumping up to 192kHz isn't going to make or break anything).
I just (also with you - but the original post didn't make it clear on your stance) prefer to track in 24-bit. I'm a whore for headroom. |
#20
I have found that sample bit depth (16 vs. 24) makes a much bigger difference in tracking and mixing clarity than does sample resolution (44.1 vs. 48 vs. 96 vs. 192).
I track in 48/24 all the time.
Insect Massage Therapist HUGE sound generation & capture facility http://www.toddejones.com |
| Why all the bits? | HapiCmpur | Newbies | 4 | 09-07-2002 14:57 |
| bits? | monstertruck | Newbies | 6 | 06-06-2002 23:43 |
| Using all of my bits... | eclips1 | Newbies | 9 | 04-20-2001 10:39 |
| bits | Olson | Digital Recording & Computers | 8 | 12-31-2000 18:28 |
