Old 02-14-2009
JonPaulP JonPaulP is offline
Senior Member
JonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond reputeJonPaulP has a reputation beyond repute
Tips for Flattening Vocals / Consistency
When I listen to some recordings I've done, I could tell if I had changed distances or angles while recording my vocals. It sound really "karaoke". I'm using a compressor/limiter so maybe my settings are wrong?
Or is there something else to it?
Also, the room isn't acoustically treated yet. I get a decent sound about 5 inches away from the condensor michrophone (though somewhat bassy, it works at times) and less desirable sound about 12 inches away.
Listening to professionally done recordings, the vocals sound flat and consistent.
I haven't really been applying any effects on the recordings except reverb. Should I be?
Old 02-14-2009
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
90% of capturing a vocal take is up to the vocalist. If you can hear "moving around" then have the vocalist stop moving around. If you can hear severe volume inconsistencies, have the vocalist use better technique.
Improperly treated spaces, especially with condensers (which typically are too sensitive for most vocal applications, IMO) will kill you every time.
If you're compressing the input chain, I'd pull that right off the bat - Generally only makes matters worse - Screws up gain staging, "fools" the engineer *and* the vocalist into thinking they're doing things that they're not (and that doesn't fix things - It enhances them).
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-14-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
What he said, get rid of the compressor. If your room sucks then remove it from the equation. Stand a hard shell guitar case open on a chair and put your mic in it facing out and sing into the case. It's a mickey mouse sound booth but it works pretty good and it's free. You'll still have to use practicle mic techniques like you said and back away on loud passages.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
My Vocals Suck, Tips? FredFredrickson Microphones 17 01-01-2009 20:55
Tips For Recording Vocals! emostrung Recording Techniques 16 02-17-2006 09:10
pink noise, spectrum analyzers, and flattening cello_pudding Recording Techniques 27 05-26-2004 13:28
Tips on Hip Hop Vocals VirtualSamana DJ & Hip Hop Production 20 02-18-2002 07:57
Flattening out the EQ on a shelf system for monitors? dabluesman Mixing / Mastering 1 06-21-2000 11:04
