Old 02-10-2009
HB1978 HB1978 is offline
Newbie
HB1978 is on a distinguished road
Mic Preamps
How important is mic preamps. If you have a good mic let's say the Sterling Audio ST66 is the mic pre still necessary?
Old 02-10-2009
buckkillr8's Avatar
buckkillr8 buckkillr8 is offline
David Gilmour's clone
buckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond reputebuckkillr8 has a reputation beyond repute
A good mic isn't going to be any good through a shitty preamp. A not so great preamp will never show what a good mic is able to do. It'll only be as good as it's weakest link.
My Gear
Old 02-10-2009
Newbie
I have an APHEX 207 two channel tube mic pre. Is that a pretty good mic pre? Or shall I upgrade?
Old 02-10-2009
KineticSound's Avatar
KineticSound KineticSound is offline
The VOICE
KineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond repute
I like those Aphex units. No frills; just good, clean gain. Paired with the Sterling 66, I imagine that sounds pretty nice.
What's the medium? Vocals? Acoustic instrumentation? Both?
David Swinehart
Owner / Operator
Old 02-10-2009
Newbie
Forgive me for being stupid, but I don't understand your question. Can you rephrase it?
Sorry, I just got it. I'm doing Vocals.
Old 02-10-2009
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Mic preamps are fairly important if you have a decent microphone.
But there is also another factor to consider; how well the mic and preamp match up. If you have a mic that requires (just for example) an amp with 65dB of clean gain in order to get the signal up to line level and you have a cheap preamp that's only rated for a clean 50dB of gain, you're going to have trouble getting a full signal.
Similarly, but arguably not quite as crucial, is that typically you want to look for a preamp that has a rated input impedance of somewhere in the 5-10x grater value than the rated impedance of the microphone in order to get decent performance matching. This i usually not a problem, but some cheaper preamps are designed at much lower impedances than that.
Not that the proper amount of preamp gain and impedance matching will guarantee a quality sound, but it can be hard to get that sound without them.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 02-10-2009
Newbie
G.
My mic is 200 ohms and my pre is 1M ohms input. I get a pretty good signal already. My mic is connected to a Pro Tools MBox 2. With all that said I still do have turn up the gain on the MBox to almost the max to get a fuller signal. But I will try using the pre in the signal chain.
Old 02-10-2009
The VOICE
Wait a second... you have a $600 Aphex pre and you've been bypassing it and going directly to the MBox?
David Swinehart
Owner / Operator
Old 02-10-2009
Newbie
Yep.
Does the pre only give gain? Is that the only purpose of the pre or is it suppose to make the vocals clearer? Forgive me for the stupid question.
Old 02-10-2009
The VOICE
Correct. The preamp provides the gain to the mic. The MBox is also capable of this (although on a much more limited basis as you have found). Assuming you're using the standard MBox 2, the max gain is only +50dB. I think the Aphex's have more like +65dB.
Ideally, run the mic to the Aphex, then the Aphex out to the MBox's line in. If you've got the digital version of the Aphex, then you can run S/PDIF directly to the MBox's digital input.
David Swinehart
Owner / Operator
Old 02-10-2009
Newbie
Great input! I will do that. Unfortunately I don't have the digital version. However, I may be thinking out of the box on this next question:
How about running my Triton Workstation Sampler Keyboard throuhg the pre, how do you think that would work?
  #12
Old 02-10-2009
That's it's function, it's job in life, yes. The idea to to boost the voltage from the microphones, which by design are low-voltage devices, up to the kind of "line-level' voltages for which all devices in the rest of the analog signal chain are designed to operate.
That said, however, for many technical reasons, different preamplifier designs can often have some effect on the total quality of the sound as well. Matching mics and pres, however, can be a black art not always predictable; i.e. one cannot simply look at the specs and determine exactly how a preamp is going to sound, or for which specific mics it will work "best". One can look at specs and determine if a preamp will provide inadequate gain, but beyond that, there's not a whole lot of predictability.
That said, I'm with David on this one; there is a distinct difference in quality between the Aphex and the MBox preamps. Only you can decide which combo will give you the sound you want for any given mix, but IMHO it would be silly to just let the Aphex sit there while you're pumping the ST66 through a bargain, entry level preamp like the MBox.
G.
Glen J. Stephan,
mixer's preamps vs. Firepod's preamps dastrick Other Equipment and Reviews 3 12-31-2008 00:31
Mixer preamps vs. Outboard Preamps doncolga Mixing / Mastering 3 03-05-2006 12:16
Preamps on Mackie mixers or rack preamps Shadowdog Microphones 35 11-26-2005 21:02
Yamaha MG Preamps vs. Mackie VLZ Preamps countrylac The Rack 6 03-16-2005 19:43
Preamps Preamps Have Question guitarfreak12 Studio Building & Display 1 11-23-2003 08:18
