Old 02-10-2009
Smileyshreads Smileyshreads is offline
Newbie
Smileyshreads is on a distinguished road
problem with cubase...
It seems every like 4 minutes i get like a skip.. say i just open the programs.. and dont load anything.. just straight plug a mic into my interface and just talk at some point within 4 minutes i get a quick skip in the audio while im talking. and you can hear it in the play back..
Old 02-10-2009
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
you most likely have a cracked version of the software....
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 02-11-2009
Newbie
I paid for my cubase...
Old 02-11-2009
Waffleness's Avatar
Waffleness Waffleness is offline
www.waffleness.co.uk
Waffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond repute
Which version do you have? Also, what spec is your computer?
www.Waffleness.co.uk
Old 02-11-2009
Newbie
I use Cubase sx3 i dont think my sons cubase 4 does it. i havnt messed with that one much, its the one with the thumbdrive.
cpu - 3.00ghz
RAM - 3.00
Old 02-11-2009
faxquo's Avatar
faxquo faxquo is offline
Under watchful eyes
faxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond reputefaxquo has a reputation beyond repute
Skipping
Have you checked the Virtual Memory settings on your computer, could be set too high. Just a thought!
I had a problem with skipping, it went away when I disabled the wireless LAN connection whenever I started Cubase. ... yeah I know...I'll eventually pull a wire to the studio.
Practice makes perfect
http://www.crossmediumstudios.com
Old 02-11-2009
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
cpu - 3.00ghz
RAM - 3.00
Thumbdrive? You mean the dongle? SX3 had a dongle too, bossman
Old 02-11-2009
Newbie
his is this box thing with a usb cable in a way looks like a mini external hardrive only waaaay smaller.
Old 02-11-2009
Faithful Departed
One of these guys?
Old 02-11-2009
Newbie
no its a small little box. with a usb cable that plugs into the box then into the computor... but anyway thats not what im asking, how do i fix my problem?
Old 02-11-2009
Faithful Departed
Top guesses:
- clocking problem. Unlikely if you are just running the one interface, but check to make sure that Cubase and your interface both think they are using the same sample rate.
- latency/buffer settings. Cubase should take care of that for you, but maybe play around with them.
- other device conflict (as noted above)
- background software ruining your life (disable antivirus, windows update, whatever else you got while recording--I turn off my DSL box to cut off the outside world)
- check your interface drivers--if it has ASIO drivers (let's hope), make sure Cubase is set to use them.
- lastly, optimize your OS (XP, Vista, whatever) for music - there are websites with checklists for that.
  #12
Old 02-11-2009
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
A few things to check:
- If you have more than one *physical* drive on your system - two drive partitions on a single drive does not count - set it up so that your data drive, where you record your music, is not the same drive as the one on which Cubase is installed. If these are EISA/ATA or PCI drives, try to set it up so that your data drive is the first drive in the buss chain. If it is a USB drive, shut down any unnecessary devices on the USB buss while you are recording.
- Run a Scandisk (or better utility) on your drives to make sure you don't have any bad data or flaky hard drive formats. Once you're sure that's OK, run a full defrag on your drives.
- When working in Cubase (or any other NLE, for that matter), shut down any unnecessary programs in your Windows system tray. Disconnect (physically) from the Internet while working in audio and then shut down any firewall, anti-spyware or anti-virus software sitting in memory. Also any unnecessary TSRs in your System Tray such as Quicktime controllers, Java control windows, etc. that just are not needed for working in audio. Of course, *make sure you re-boot and reload your anti-malware and firewall stuff beofre you re-connect your Internet connection*.
- When working in Cubase (or other NLE), learn to use the "lock" or "freeze" function in that software to keep the amount of real-time plug-in processing to a minimum.
- Make sure you have the latest *stable* (not beta) drivers for your audio interface or soundcard installed.
- Check the Cubase manual or Cubase support forums for optimal Windows and cache memory system settings and adjust to them, if necessary.
EDIT: Oops, MSH beat me to a lot of these by 5 minutes
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #13
Old 02-11-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Your problem mimics pirated software. You may have paid for it but using it without a dongle means it was hacked.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
  #14
Old 02-11-2009
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
You haven't mentioned what type of interface you're using...
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
  #15
Old 02-11-2009
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
I'm pretty sure he said he is using a dongle, and his son has Cubase 4 with a usb dealymabobber.
Mine has the same issues sometimes, and it's usually some background program. I don't understand why software manufactures feel they have to run a crapload of programs in the background.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
  #16
Old 02-11-2009
Originally Posted by NL5 View Post
I'm pretty sure he said he is using a dongle, and his son has Cubase 4 with a usb dealymabobber...
Sorry I didn't see that. You mean his reference to a thumb drive?
  #17
Old 02-11-2009
Waffleness's Avatar
Do a ctrl-alt-del, go to processes and sort them in order of 'amount of memory used'.
Cubase should be using the most resources. Below that, there shouldn't be anything close if your computer is releatively clean. Look for programs that shouldn't be there. Examples would be iTunes, virus scanners doing their thing, update software such as quicktime or java.
  #18
Old 02-11-2009
NL5's Avatar
NL5 NL5 is offline
Unpossible!
Yeah. I thought he said he had one. It is essentially a thumbdrive. At least mine is. Everybody focused on the thing he said went with his son's C4.
Although, I did see in another thread that he had the Mercury Waves bundle and a Perception mic - that doesn't make much sense.......
  #19
Old 02-11-2009
Newbie
ok thank you guys. i will look into this later today and try different things out. as for now i gotta get ready to go. gonna see Journey live today =] kinda like a vip concer =] 60 people max
Cubase SX problem Scrubucket7 Cubase User Forum 1 07-04-2006 18:50
Cubase problem. Tifstorey Cubase User Forum 19 05-21-2006 01:40
Problem with Cubase heybulldog Digital Recording & Computers 6 05-22-2005 19:08
Cubase Problem bknot1 Cubase User Forum 4 06-20-2004 03:02
Cubase sx problem fizzygreen Cubase User Forum 1 12-16-2003 17:10
