Pro Tools noob question...
Hey all. I am wondering about simultaneous track recording with the 003 products. Is there away to expand the number of inputs? For instance, say you're recording a full drum kit and you're wanting at least 11 mics on the kit, plus a scratch guitar or vocal. I know this may be a super simple question for most of you but, like the title says....I'm a noob to this.
***could you eat the mic please, thanks*** www.myspace.com/undertheredar www.myspace.com/upperroomrecordingstudio |
The only way to expand the number of inputs for simultaneous recording is by using multiple interfaces. Each digi003 only has 8 analog inputs. You would have to add a second digi003 (which would give you a total of 16 inputs). Unfortunately, that would be the only way.
Hmmm....seems like there would have to be another way, I guess you could have a rack and mixer right? So how would you link the two interfaces?
If you are using Pro Tools LE or M-Powered then you are out of luck and can only run 1 interface at a time. If you have PT HD then you can run whatever you want. If LE is your modus operandi then you are in for an expensive solution as you can only use Digidesign products. M-Powered uses M-Audio products as well and they make an 8 input firewire interface for $699.99 via Musician's Friend.
Not sure if that helped but I tried at least. |
That helps a ton, any information is good information.
So plain and simple, in order to run pro tools and be able to record more than 8 tracks simultaneously....what do I need?
Well, plain and simple you need an interface with 8 inputs. On a side note be sure you are running firewire when recording 8 simultaneous inputs since USB 2.0 cannot handle that much information. There are interfaces with 8 inputs with USB but do not waste your time with these.
However, if you are running the 003 then you are more than likely running LE, correct? If that is the case then you still have to find a Digidesign interface with 8 mic inputs. Like I said before, Digidesign is not cheap but look at their website and then search elsewhere to find a slightly reduced cost product. Hope that helps.
Soon to be the greatest band in the tri-county area: http://www.myspace.com/readysetemo |
Lots of bad/not entirely correct information floating around in this thread. You don't need a new interface to get more channels, you need another pre-amp with ADAT out. If you have a 003, it has an ADAT/"Lightpipe" input on the back that can handle 8 channels of audio by itself, thus giving you 16 channels of audio (or 12 if you don't have any other pre's going into the 4 non-pre-amplified channels on your 003).
I recommend this one: http://www.gigasonic.com/Presonus-DigimaxLt.html Or in a pinch, this one will work (although as a general rule, try to avoid Behringer gear): http://www.gigasonic.com/Behringer-ADA8000.html
www.myspace.com/ironthrones - my sweet metal band www.myspace.com/stevehenningsgard - my recordings |
Your band is sick by the way....kudos Sweet! So if you're running a 003, what's the limit on inputs you can have? Sorry to be so confused about this, just new to it....
18 inputs max on the 003
8 analog (4 pres and 4 line), 8 ADAT Optical and 2 S/PDIF http://protoolsforum.com/ProToolsLE1.html (a little dated, but 98% complete)
www.redlabaudio.com |
#12
Nope i'm starting from the ground up....so i'm pretty free to do anything
#13
Well hot damn! Stay away from Pro Tools then hah
#14
Are you doing just midi or more audio recordings.
#15
He said he'd like to do at least 11 drum tracks plus scratch tracks. Did you even read his post?
#16
Edit: He just said: Quote:
#17
What the hell are you talking about?
#18
He just said "For instance, let say". So he's not gonna do this one time or his whole career...
#19
have you considered?
Step, have you thought about Ableton Live for recording drums? Some fun beat stretching/editing features and song arrangement stuff that might suit your style.
Plus, you wouldn't be wed to Digidesign hardware and so would have some less expensive options for audio input available. |
#20
I'm assuming cause the arm and leg you have to give to get your hands on a piece of equipment....granted, but If i want to run with the big dogs i gotta quit eating kibble and get some real meat....bad analogy but hopefully you see where I'm getting at.
I've looked and played around with a lot of different DAW but I keep getting drawn back to P.T. As much as people hate to admit it, it's really becoming the standard in studios, at least that's from my view. SO this is what I'm looking at running a Digidesign 003 rack, a Presonus Digimax for additional inputs via lightpipe, all Firewire to Pro Tools 8 LE. Would sync'r be necessary or does the 003 take care of that?
#21
#22
i don't get it....
#23
#24
use a multi patch and a adatconverter
#25
TIf compatibility with other studios is of importance to you (as it was to me when I switched), Pro Tools is definitely the way to go. It's not the best software out there, and even many pro's will attest to this, but it's definitely without a doubt the most prevalent.
However, if it's not incredibly important to be able to transfer projects back and forth between studios, there are many fantastic pieces of software that I'd recommend over Pro Tools (Sonar & Logic are fantastic), because Pro Tools drastically limits the hardware you can use, as well as the plugins you can use (although there is a fantastic program out there that allows you to use non-pro-tools plugins) Last edited by steve.h; 02-09-2009 at 18:29.. Reason: *Removed unnecessary negative commentary in the interest of keeping the thread on-topic. |
| Noob question from a not so....eh...noob? | Markaholic | Recording Techniques | 9 | 04-28-2008 21:16 |
| Noob question from a not so....eh...noob? | Markaholic | Recording Techniques | 0 | 04-27-2008 10:48 |
| Noob Question from a not-so noob! | Markaholic | Newbies | 10 | 03-13-2007 16:18 |
| Such a noob question I am...... | pranaearth | Microphones | 45 | 07-14-2006 16:01 |
| Noob question | seansigep | The Rack | 8 | 03-03-2006 16:32 |
