I'm new at home recording....I have a Lexicon Omega and Cubase LE. Cubase seems to have loaded properly...but...I look in the device menu for "Drivers"...and I don't see "Asio".....should I be looking somewhere else? Secondly.....I've tried to record a vocal track....and it is barely audible when I play it back. My only resource has been the booklet that came with the gear. Also.....Is it possible to enhance the vocals(reverb etc) using the Lexicon and Cubase....if I'm trying to record to a Karaoke site(Singsnap etc). Any direction you can provide....would be much appreciated....Thanks
I would guess that since you can hear the playback (even if its faint), you have the equipment installed correctly. If you didn't hear anything or get any signal, then I would think otherwise. But perhaps you have an issue with a pre-amp signal or something like that going into your board. I am sure you have checked your gain going in, right?
Yes, you can add all kinds of FX... actually, I think on LE you can only add 2 per track. But if you set up an FX track and use the FX sends, that will help you. Add, reverd, compressions, etc as you see fit. Hope that helps. |
If you look on the Cubase LE CD, there are a couple of manuals.
One is 'getting started', and the other is a more detailed manual.. might even be a hundred or so pages. I printed them, put em in a binder, read them... and have to re-read them soon i think. lol As for the ASIO driver... if you can't find it, Cubase LE works with the Asio4all driver (google it and download it if you need it) As for reverbs and stuff.. yes Cubase LE can do that. Good luck.. for me it has just been getting past one little hurdle at a time. lol |
Thanks for the info....much appreciated.....I'll take the slow approach...and see how it goes.......there doesn't seem to be eneough hours in the day....to get involved with it....there's a ton of stuff.....but......it'll be fun...once I get it off the ground....and can do some decent recording...thanks again!
Amen to that. What mic and preamp are you using, how are you monitoring and what levels are your meters when you're recording?
moved to another thread. a thousand mea culpas
![]() Last edited by billy3000; 02-26-2009 at 23:57.. |
Thanks, |
>>Hi Bill, you should start this question in a new thread, instead of attaching to someone else's. Thanks<<
oh, ok. sorry about that. will do! |
| getting started with cubase le 4 | jibba | Cubase User Forum | 3 | 02-24-2008 00:34 |
| cubase getting started | dmbfan1981 | Cubase User Forum | 1 | 10-05-2005 09:19 |
| Getting Started With MIDI and Cubase LE | Bigsnake00 | Cubase User Forum | 8 | 01-23-2005 06:12 |
| Help just to get started | funkymf | Cakewalk / Sonar Forum | 3 | 10-28-2004 09:49 |
| getting started with cubase sx | marduk | Cubase User Forum | 2 | 05-17-2004 16:02 |
