Old 02-06-2009
stupidfatnugly stupidfatnugly is offline
Dedicated Member
stupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond repute
instrument cable?
can you use an instrument cable from your monitor to your interface?
Old 02-06-2009
didgijimmy's Avatar
didgijimmy didgijimmy is offline
vexed
didgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond reputedidgijimmy has a reputation beyond repute
if i understand correctly...
Yes you may do this, however typically you have two monitors, so I'm not exactly sure if you are speaking of speaker monitors or not. most interfaces have a 1/4 jack in for instrument cables, and your speaker will need them too. Make sure you get balanced trs cables, they make a difference and you can't take any chances while mixing
Old 02-08-2009
Dedicated Member
yes, I'm talking about monitors
I just want to know if I need to buy new cables - "non-instrument" to go from each monitor to my mbox or if I can just use what I have which are 1/4'' instrument cables.
Old 02-08-2009
snellular5's Avatar
snellular5 snellular5 is offline
neil young whore
snellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond repute
Not really i use standard instrument TS cables to hook my monitors up, although i believe TRS have better ground noise rejection.
Old 02-08-2009
didgijimmy's Avatar
vexed
ok,
You can use your standard instrument cables, especially if you are low on funds, but if you do come into some cash then a simple upgrade to your rig would be balanced TRS's. Mixing is one of those things that the smaller components are just as important as the big expensive ones.
Old 02-09-2009
Dedicated Member
balanced TRS's
ok thanks guys
when I get the money I'll get the balanced TRS's
Speaker Cable vs. Instrument Cable Zaphod B Guitars and Basses 3 02-19-2008 17:36
Instrument cable andycerrone Newbies 9 12-08-2006 13:11
Core Cable X2 1/4" Instrument Cable ericlingus Other Equipment and Reviews 0 02-11-2006 01:29
can i make a balanced instrument cable with Mic-cable-wire ? earworm Microphones 12 07-23-2004 05:40
pro instrument cable recorder Guitars and Basses 0 03-02-2001 17:42
