Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 02-06-2009
sslizec sslizec is offline
Registered User
sslizec is on a distinguished road
MIxing down
Recorded a couple of tracks and now I want to mix down. I go to "export', audio mixdown and choose mp3. The result I get is really surprising...the quality is extremely bad, like in an old boombox.
I apparently do something wrong, but can't figure out what exactly!???? (I use default setting when chosiing how to save the mixdown)
Thanks
Old 02-06-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Guessing I'd say you probably tracked too hot. What was your average lvl when tracking? What quality mp3 are you choosing when exporting?
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 02-06-2009
Slowjett Slowjett is offline
Force of Nature
Slowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond repute
Doubt it, just sounds like he's describing crappy mp3 compression.
sslizec,
Try using the highest sample rate that the mp3 will allow. In fact just get a different encoder altogether. Find 'LAME' and have cubase use LAME's dll to encode the mp3. It makes quite a difference.
Old 02-06-2009
Registered User
:Slowjett
-- Try using the highest sample rate that the mp3 will allow.
I use 20 kBit/s; 8000Khz, Stereo
In the list of what's available the highest is 320 kBits/s 44.100 Khz - is the one that I'm supposed to be using?
NYMorningstar:
- Nope, the levels were barely yellow in the monitor window so I doubt it was it. The only thing I can think of is that is that for line signal (keyboard) I use sound card with the guitar input, but I was told that that's not a biggie for home recording as line input will simply sound a bit more quiet and that I should adjust the volume of the input a bit.
Thanks guys.
Old 02-06-2009
Chili's Avatar
Chili Chili is offline
Moderator
Chili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond reputeChili has a reputation beyond repute
Originally Posted by sslizec View Post
:Slowjett
In the list of what's available the highest is 320 kBits/s 44.100 Khz - is the one that I'm supposed to be using?...
Thanks guys.
Yeah, the 20kb/s is going to sound like crap. The 320kb/s will sound much better. Theoretically, 128kb/s is close to radio quality.
peace.
Find my tunes here >>> http://www.soundclick.com/bands/page...?bandID=741321
Old 02-07-2009
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
:Slowjett
According to Nyquist Theory, you are only hearing up to 4 khz, which is barely the top fundamental of the piano. There's a reason it sounds bad
Yeah, 128 kBit is about Radio Quality, though cymbals always seem to sound flat at that rating. Go with 320, or just render a WAV.
Old 02-07-2009
doctorfungi's Avatar
doctorfungi doctorfungi is offline
Junior Member
doctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond reputedoctorfungi has a reputation beyond repute
Change it to 320kbps/44.1kHz. Problem solved
If you're making files for an audio CD, however, make sure you export as a 16-bit/44.1kHz WAV file.
Mixing Mp3s? & The Basics of Mixing Ur Music Antwine Mixing / Mastering 1 10-02-2005 06:24
Mixing Entire CD vs. Mixing One Song... Robertt8 Mixing / Mastering 7 04-04-2005 16:07
the mixing contest's are really improving my mixing skills StudioMxpx MP3 Mixing Clinic 2 08-14-2004 15:49
I Need Help Mixing. Not putting things together, I mean SERIOUS MIXING Mr. SoL DJ & Hip Hop Production 12 02-02-2002 22:23
