is there a multimedia driver that supports two interfaces at a time?
Hi I own a podx3Live and a presonus inspire(with cubase se3), I have my studio already setup with the inspire, and I want(and I'm wondering if it can be done and/or somebody has managed to do it) to record via the podx3 inputs and listen via the ispire outputs. I tried to do it with the asio multimedia, but I couldn't. Does anybody know about a multimedia driver capable of doing this? It comes in handy because I want to record with the pod x3 dry signal , while listening to the fx'd singal through the inspire, and use the plugins to add the fx later in case what I recorded sounds better later with different fx setup, but I don't wanna record it 20 times to see which preset sounds better. And you know sometimes things sound good the first time and some other time you go, "I should have done this", well if I record a dry signal I can change it later. But most of my recordings I've done with the inspire and I don't wanna go back and forth with one or the other interface, so if I can use them both at the same time that'd be great.
The rule is 1 ASIO driver active at 1 time.
Saying that, some people reckon asio4all (dont shout at me for mentioning it ) has been rumoured to support more than one asio at a time, so might be worth a look. Its less than reliable when more than 1 is active though. You can find it on google. |
btw this is the one time i woulda suggest asio4all i've heard of guys running mutiple interfaces on it when the manuf. wouldnt play well together... as i understand it you can only specify one driver at a time so you better have one that both can use...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
tried asio4all but I can't seem to do it. Heard of any other?
| Audacity supports ASIO | danny.guitar | Digital Recording & Computers | 0 | 02-02-2008 05:02 |
| Driver for multimedia 8 won't load | Delreek | Alesis Forum | 0 | 11-10-2006 14:21 |
