Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 02-03-2009
mcl116 mcl116 is offline
Junior Member
mcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond reputemcl116 has a reputation beyond repute
problem with stereo in?
so I was trying to record for my first time using cubase but ran into a problem immediately!
it says I have to select stereo in>left but that is not a choice. the only time right or left is an option is for stereo out.
how do I fix this?
Old 02-03-2009
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
What soundcard do you use and what version of cubase? What are you recording using what hardware? Did you read the manual???
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 02-03-2009
Junior Member
I'm using a Presonus Audiobox- I read the little downloaded manual that shows you how to get started (if you could point me towards something more in depth that'd b great). I set up the audiobox as the ASIO driver and then it says it choose left for stereo in but that's not an option. When I click on it, it just says stereo-in with a check. When I click stereo-out it gives me the option of left or right, so I know something is a little screwy here.
edit: I got that working but now it's not reading what I play. The meter is not showing anything but if I turn the gain up on the audiobox the clipping light will go on when I turn it up too much. what do I do about that?
Old 02-04-2009
Waffleness's Avatar
Waffleness Waffleness is offline
www.waffleness.co.uk
Waffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond repute
When you create a new channel, it needs to be MONO not stereo. This will then give you the option of choosing which input you want.
As for making it record properly - make sure you arm the track. Click the little red circle on the track. This will tell the program to "record here". If you have done this, have the right input selected and have the gain set, click record.
Stereo to mono problem Village-Idiot Mixing / Mastering 2 06-05-2008 02:11
HS 80 m stereo field problem punkrcker32 Studio Building & Display 2 05-27-2008 08:26
HS 80 m stereo field problem punkrcker32 Recording Techniques 8 05-26-2008 22:55
Stereo Problem... johnnypraze Cakewalk / Sonar Forum 7 04-29-2003 21:10
Digitech RP-10 stereo problem dabluesman Other Equipment and Reviews 4 06-08-2000 21:05
