Searching smaller words
The four character lower limit is a real PITA, as most microphones have two-character or three-character names.
WARNING: the index could grow significantly. ![]() WARNING: the tables will be locked during this process, so this will require downtime; I have no idea how long---that depends on how fast the server is and how big the tables are. It might be a good idea to dump the tables first and try it offline on a different machine. With those warnings in mind, to change the indexing, first make sure the BBS is using MySQL fulltext indexing and not the built-in vBulletin indexing. If it is using the vBulletin searching, that could explain why searches bring the board to its knees.... ![]() Once you have switched to use the MySQL indexing (read the vBulletin docs for info), the next step is to tune MySQL appropriately. This is a multi-stage process. First, in your MySQL configuration file (e.g. my.cnf), add: Next, restart MySQL. Next, rebuild the fulltext index for any tables that have them. To do this, for each table, type: See http://dev.mysql.com/doc/refman/5.0/en/show-index.html for info. This should show the indices for that table. For any index of type FULLTEXT, drop the index with: See http://dev.mysql.com/doc/refman/5.0/en/alter-table.html for info. and recreate it with: See http://dev.mysql.com/doc/refman/5.0/...ate-index.html for info.
| Making an MP3 smaller? | elenore19 | Newbies | 10 | 03-09-2007 19:09 |
| Smaller speakers these days | Kasey | Mixing / Mastering | 4 | 09-06-2005 08:09 |
| Comparable to Q10 but smaller | jdier | Digital Recording & Computers | 0 | 03-29-2005 10:19 |
| Trading rp8's for smaller..... | judeholland | Other Equipment and Reviews | 0 | 12-15-2004 10:38 |
| smaller amp, suggestions? | vaporpark | Guitars and Basses | 10 | 04-01-2004 14:04 |
