Thread Tools | Display Modes |
Will Sending 2 Different Signals to Stereo Compressor Interfere W/ Each Other?
i have several RNCs. I know that they are not dual mono comps - i guess they are linked / stereo or sumpthin'.
let's say i have two signals i wish to compress with the same settings - since that's really all you can do with the unit. say maybe two toms or kick and snare. using this scheme, will the two signals interfere with each other as they pass through the compressor. like if the release of one signal is not done before the next transient from the other channel enters its circuit - will it affect or re-squash the first signal before it is finished... if that makes sense tia
"emotions are the consequence of reason" -- ayn rand |
Turning the stereo button off would cause them to operate independently. At least this is how all stereo compressors I have used work. Last time I used one was on a bass guitar. Triggered off the DI and compressed both the DI and a mic (B52) on the cab. |
The RNC's are stereo all the time.
The answer to your question is "yes", the signals will affect each other. If you set it to a long release they will affect each other less. Or less noticeably let's say.
http://www.misterpotts.com |
Thanks Sonic.. always precise, concise and relevant.
on a different note. are there any studio tricks that you can take advantage of the RNC in this way? like for example can u run bass through one channel and anther intrument in another channel that will make something cool happen?
http://www.rane.com/par-d.html 'ducker' A dynamic processor that lowers (or "ducks") the level of one audio signal based upon the level of a second audio signal. A typical application is paging: A ducker senses the presence of audio from a paging microphone and triggers a reduction in the output level of the main audio signal for the duration of the page signal. It restores the original level once the page message is over. Another use is for talkover.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
| Would Sending an Analog Mixdown to a Minidisc Stereo Deck Steal the "Warmness"? | myurbanodyssey | Analog Only | 4 | 09-25-2007 13:05 |
| FA: DBX 162 Stereo Compressor | Revolution | Free Ads for Music / Recording Equipment | 1 | 10-12-2006 22:45 |
| FS: Joemeek C2 Stereo Compressor | Diffusion | Free Ads for Music / Recording Equipment | 1 | 10-03-2005 17:57 |
| Recording mono signals to stereo | bbourgon | Newbies | 1 | 11-08-2004 18:27 |
| a compressor that won't let my signals clip. | wes480 | The Rack | 19 | 10-22-2002 15:52 |
