ADAT input question
Hello,
I recently just acquired a few blackface ADATs and being unfamiliar with them I've a question in regards to the input routing. With all tracks enabled, putting signal into channel 1 shows up on other tracks. One of my machines shows input on channels 1,3, and 7. The other machine shows input on 1,3,5,7. Is this normal or is there something wrong with these units? Channel 2 does the same thing but shows input on other channels. I don't see anything about this in the reference manual. Anyone? |
no, input on channel 1 should only show on channel 1 etc. However,please explain your setup i.e. are you going from analog mixer,digital mixer with lightpipe etc.
People always seem to embrace the future then long for the past |
I've just been running signal into the analog inputs to test the units and them monitoring on the analog outputs. I've confirmed that channel one shows up after recording on multiple tracks. So there is no internal signal routing that can make input 1 go to any other input than track one? Thanks
Pretty sure this is the way the inputs are normalled so that you can get to all 8 tracks with a 4-buss console without having to use "y" cords or some other signal splitting devices. Some Fostex machines did the same thing. Using 1 output to 1 input per machine will cancel this internal routing.
Rick Ruskin Lion Dog Music - Seattle WA http://liondogmusic.com |
I figured it was something to do with routing. It is strange the this is not documented in the reference manual. Thanks for your help.
I haven't been on Adats in quite sometime but I know there was an option to change this on the XT's, Lx 20's and Xt 20's. I have no idea if it worked for the blackface adats or not since I never used one. You might try reading one of those manuals and then giving it a go on your blackface. Sorry I can't be more specific, but I haven't turned them on in ages.
| mic input question | paulf | Microphones | 6 | 10-02-2006 17:25 |
| to ADAT or not to ADAT (input that is) | guttapercha | Recording Techniques | 4 | 03-29-2006 10:35 |
| Does the RME Multiface ADAT input transmit all 24 bits? | Simmons | Digital Recording & Computers | 0 | 12-05-2003 05:10 |
| input question | mike628 | Cubase User Forum | 2 | 10-21-2003 14:34 |
