Tascam 38 - No input/output
![]() Tascam 38 was working fine. Opened back panel and inadvertently let RCA cable rest on motherboard. Herard a faint "zzit" sound. Now have no input to all tracks, no output from tape on all tracks either. When I backfeed a tone signal into inputs the VU meters come up. HELP! |
Hopefully ou shorted a power rail or 2 and just need to replace fuses. Regards, Ethan PS Take a deep dreath and Don't panic! ![]()
In Sunny Vancouver ..... (Washington) |
Thanks much for the reply and comments. It's in a shop. Been there for a month now. They haven't looked at it yet. Haven't used them before. Getting frustrated. Before it went in...
I did check the fuses. Are there more than on the main block behined the rear panel. All transport functions are fine. Remote works fine. Function selects work fine. I can hear the record relays on each channel when I engage record function. I pulled one of the channel PCB's and tried a spare that came from "good" evilbay seller to no avail on that particular channel. I had not previously tested the spare channel card though. Anyone know of a good tech in the Kansas City area if this shop can't fix or wants to rake me?? |
Thanks again Ethan for your thoughts. It was working perfectly until I let an RCA cable end touch the motherboard. Then no input to VU or tape record, and no output from previously recorded tape. Anybody have any idea why? Any help would be much appreciated.
Blown transitor on the Power Supply PCB...Q308? Now finding out somthing is amiss with output select when in "Synch" mode and causing one of the fuses to blow...hopefully another relatively easy fix. Something about one of the 24V power rails shorted? Should have it back in a couple of weeks. Missing my baby!
| Tascam 388 Stereo Output Issue - No R output | edwood83 | Analog Only | 12 | 08-05-2008 13:23 |
| output in input | gourbon | Newbies | 1 | 03-26-2005 05:30 |
| input/output | sblair | Cubase User Forum | 0 | 07-07-2004 10:14 |
| I need some input or output... | deepseasquid | MP3 Mixing Clinic | 2 | 08-08-2003 19:32 |
| i just got a pre-amp..what..do i put it on..for output..an input | MicFlo | Newbies | 3 | 02-13-2003 21:47 |
