Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 01-14-2009
Alexrkstr Alexrkstr is offline
Senior Member
Alexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond reputeAlexrkstr has a reputation beyond repute
Question Who Has Upgraded From USB to FireWire?
Just wanted to hear what type of difference you experienced using PTLE and upgrading from a USB interface to a FireWire.
Could you add more tracks? RTAS? etc? or did you not see a difference?
Old 01-14-2009
pezking pezking is offline
Force of Nature
pezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond reputepezking has a reputation beyond repute
The interface will not affect the performance of the plugins or track count.
All it will affect is the sample rate*, and the i/o count.
*by this I mean that with the Mbox 2 family (except the Mbox 2 Pro) the session will be limited to 48kHz. With the 003 Family, and the Mbox 2 Pro, you can use sample rates of up to 96kHz.
Old 01-14-2009
Senior Member
Hi pezking,
Actually I believe that the computer performance is a little bit optimized since USB consume some CPU power.
Also, if the data goes from:
Instrument >> Interface >> CPU >> HD
there is one more step than going direct when you daisy chain:
Instrument >> Interface >> HD
USB transfer speeds are lower than FireWire so you will be limiting the number of tracks as well.
If someone has different information it would be interesting to know...
Old 01-14-2009
Force of Nature
If you're specifically referring to Pro Tools, whether or not you use the Mbox 2 Pro or the Mbox 2 (or mini or micro) it will not affect the performance.
Yes if you're trying to do multiple channels of I/O a firewire interface has various benefits, but that's not really the question you've asked.
You will be able to achieve the same performance with the same settings with any given Pro Tools LE interface. I can't stress that enough.
Old 01-14-2009
Senior Member
Hmm...My question is only CPU load related, let me re-phrase it:
Will I see less CPU consumption (processing load) in the computer if I use FireWire instead of USB?
Logic on why I think the answer is yes is above.
Old 01-14-2009
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
you're still going to need to go from Interface to CPU to HD....the processor needs to do it's job first before you write to disc. Otherwise we'd just plug hard drives into our Mboxes
any CPU usage differences (if any) between USB 1.1 and Firewire will be minimal, especially with processors today. That being said, the other benefits of firewire over USB 1.1 are much more important (sample rate & extra I/O)
www.redlabaudio.com
Old 01-14-2009
Senior Member
Meh... I called Digi and they answered the question for me.
Question - Is it worth to go from a USB to a FW to reduce the load on the CPU?
Answer - It will not reduce it that much if at all unless you are planning to record multiple tracks at once because of it's bandwith.
Old 01-14-2009
wreckd504 wreckd504 is offline
Force of Nature
wreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond repute
isn't that what benny just said?
www.myspace.com/heavyrainproductions
Old 01-14-2009
Senior Member
Yes, very close and it happened at the same time... I just happen to be at home now
Old 01-14-2009
maybe I should go work at Digi
www.redlabaudio.com
Old 01-15-2009
Force of Nature
And me!
Maybe I should go work for them lol
Upgraded CAD M9 tub mic - $250 Bob's Mods Free Ads for Music / Recording Equipment 3 07-22-2007 07:52
I just upgraded... surfmaster Digital Recording & Computers 0 02-05-2007 17:48
Audiophile2496, V-Amp (upgraded) DaisyCutter Free Ads for Music / Recording Equipment 7 06-19-2003 13:35
upgraded to winxp docwilson50 Cubase User Forum 1 05-10-2003 14:30
Just upgraded on my old BE6... Slackmaster2K Digital Recording & Computers 1 10-11-2001 18:20
