If I track to a cassette four track, I'd like to take the output from tape on the same pass and immediately dump it to digital on separate tracks and mix ITB. I have no need for overdubs - this is live jazz. (This is stuff that will end up on CD anyway - it has to go digital at some point).
I've noticed an improvement when I record to my Tascam 22 this way. Because it's the same tape pass, any fluctuation in tape speed is completely inaudible. (Not that there is much, my Tascam is pretty healthy thanks to you folks ). My idea is that doing it this way will remove any frequency wobble from the cassette recording and make a substantial improvement. Sound reasonable or is my logic flawed? If not, what 4-trackers could do this? |
If you're set on using this technique, maybe try a 34, 34B or 22-4.
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
I would like to take it to live gigs. I don't really want to deal with that kind of cartage.
For that "purpose" You can try using two (or more) three head two-track cassette decks of the same model and preferably as close as possible of the same condition/performance. Actually a very slight difference in performance may "generate" an extra 'spice' of mysterious nature to your result
. Try to experiment, see how it works. |
The problem is that I'm one of the musicians too. There's no way I can deal with changing reels and stuff and having the gear on stage with me. Cassettes, sure.
Make a loop!
-MD |
Why not just record your gig with what you already have? No extra machines to carry. No reels OR cassettes to change. Clean audio, straight from the instruments or mics.
If you want to warm it up later with analog tape effects you still can. In your home, at your leisure, use a decent 3 head 4 track reel to reel to dub 4 new files, which courtesy of the instant playback will all be in synch with each other. If you want, line them up manually with your original 4 digital files and you have the best of both worlds. Cheers Tim |
| WTT: Digital 8 track for cassette 4 track | UnholyDemon | Free Ads for Music / Recording Equipment | 9 | 12-31-2007 17:32 |
| rare item for cassette heads | Dr ZEE | Analog Only | 9 | 10-25-2007 12:34 |
| 3 head cassette deck vs. 2 heads? | studiodrum | TASCAM User Forum | 2 | 07-26-2004 07:30 |
| 4 track-8 track cassette question | Rimshot | Analog Only | 15 | 07-18-2003 18:31 |
| Sound quality - 4 track vs. 8 track cassette | trag-o-caster | TASCAM User Forum | 2 | 08-08-2000 20:52 |
