Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 01-12-2009
bluesallday bluesallday is offline
Newbie
bluesallday is on a distinguished road
XT20: 48 kHz or 44.1 kHz,which one to use?
I have an xt20 adat.Which do I set it for 48 or 44.1,what are the differences and what do they mean anyway?I just have a home studio where I mix the adat down to a cd recorder.
Old 01-12-2009
RRuskin RRuskin is offline
Rick Ruskin
RRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond repute
The numbers refer to the sampling rate (in kHz) being used.
If mixing through an analog console, I'd use 48kHz. If digitally transferring to a computer for editing & mixing, use the audio CD rate of 44.1.
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
Old 01-13-2009
eh91311 eh91311 is offline
recordist
eh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud ofeh91311 has much to be proud of
You should probably record at the highest resolution the XT20 will record, which is 20 bit, 48k. I think the XT20 sounds better at 48k, compared to 44.1.
Old 01-14-2009
Newbie
Thanks,I thought the higher rate would be better.
Old 01-15-2009
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
CD is 16/44.1
If you're going from the XT to CD via a digital interface you should use 16/44.1 while recording tracks on the XT. The digital down conversion process from 20/48 to 16/44.1 negates any advantage of recording at 20/48. If you’re using the analog out of the XT20 to the analog in of the CD recorder then yes record at 20/48.
Audio degradation from digital-to-digital conversion is generally worse than analog-to-digital conversion. Avoid converting up or down in the digital domain as much as you can.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 01-16-2009
Newbie
Yep,everything is pretty much analog.From xt20 analog outs I'm going to an analog mixer and outs to the cd recorder analog inputs.Nothing fancy.Thanks for the info!
Adat XT20 DanielJohn Free Ads for Music / Recording Equipment 0 09-22-2003 22:50
Format from xt20 to 16 bit at 44.1k flatrockrecordin Alesis Forum 2 04-13-2003 07:26
ADAT XT20: Bad out YamahaPaiste Alesis Forum 2 04-22-2002 10:38
XT20 TRAILBLAZER Alesis Forum 2 06-08-2000 21:17
XT20 TRAILBLAZER Newbies 2 05-23-2000 10:00
