Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 01-11-2009
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Routing and monitoring in Cubase
Hey all.
Just got a Profire lightbridge which gives me 4 channels of ADAT. I was using an RME HDSP card, I have 3 AD/DA converters units for 24 channels input.
Here is my setup:
ADAT 1: Mytek 89x96 8 channles in
ADAT 2: Lucid ADA8824: 8 channels in, 8 channels out
ADAT 2: Behringer ADA8000 :8 channels in, 8 channels out
I premix my keyboards and bring them in on ADAT 1: channels 1&2
My main monitor outs are ADAT 2: channels 1&2.
I am having trouble figuring out how to route external instruments. When I set up an external instrument I can set the return Bus to ADAT 1 channels 1&2, but then those channels are no longer available as inputs?
How do I tell Cubase where the monitoring channels are for external instrument? it seems to output to ADAT 1
How do I record this instrument if the return buses are not available as recording channels?
Thanks in advance for any help!
The fact that no one understands you doesn't mean you're an artist...
Old 01-13-2009
Waffleness's Avatar
Waffleness Waffleness is offline
www.waffleness.co.uk
Waffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond repute
Originally Posted by fraserhutch View Post
Hey all.
Here is my setup:
The monitor button in Cubase will send the channel straight back out the stereo out.
If you want to monitor the instrument through another out, I suggest you setup a send. Select "New Send" and route it to where you want. Now go to your track, and in the sends options on the left, send 0dB out the channel you just created.
Does this work? Have I understood the problem correctly? I fully expect there is an option somewhere to send the monitor signal somewhere else. I would guess in the VST Connections menu, but I am not with cubase right now so cant check.
Old 01-13-2009
Flypaper for freaks
Hmmm, thanks for the reply, I'll have to look into that. I'm at worki too, so I'll check it out tonight.
I was putzing around with VST connections last night and may have hit a working solution., but the output was soooooooo soft I had to putz around with my gain settings which ultimately hosed everything, so it's back to the drawing board again.
Thanks, and I'll get back to this tonight!
Old 01-14-2009
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
It will make the channels you choose no longer available. External instruments behave just like a VSTi so hit F11, select the device, and it will open audio tracks under VST instruments in the inspector window just like a softsynth would except you will need to do a realtime mixdown to actually record the track. This can be really useful for automating stuff if you have a device panel setup for said instrument. There is a return gain trim under the VST connections next to the delay adjustment.
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Help. Track monitoring/routing and recording Outlaws Don't Fear The Reaper 1 01-04-2009 15:22
Cubasis routing for multitrack overdub monitoring sleepnotwork Cubase User Forum 2 05-17-2004 13:03
Monitoring/routing problems puffin Digital Recording & Computers 2 11-30-2003 08:38
Routing in cubase rockem Cubase User Forum 32 09-06-2003 07:19
Delta 1010lt routing/monitoring options Jagular Digital Recording & Computers 1 06-21-2003 14:46
