Recording with reverb and no latency
A guitarist came in and wanted to record with some reverb. I loaded up a plug, and he said he could hear a delay. I hear it too, but just deal with it - however with him it appeared to affect his timing.
I put Pro Tools in low latency monitoring mode and the delay went, but the reverb plug deactivated as well. I tried to put the verb on a aux channel, but sends are disabled as well when low latency monitoring is on. How do you all record with reverb and no latency??
www.myspace.com/heavyrainproductions |
lower your buffer settings
a) Lower your buffer settings to as low as they will go without glitches
or b) Use an outboard reverb unit. |
put the reverb on the aux and then turn off low latency...but keep a lower buffer size. It's the direct monitoring that is screwing him up...and this is because your putting the reverb on the audio track causes a delay in both the wet and dry sound.
www.redlabaudio.com |
| Latency in recording | Oxcyde | Digital Recording & Computers | 2 | 08-29-2007 04:16 |
| sudden recording latency! | freakkguitarist | Recording Techniques | 6 | 06-14-2006 09:15 |
| Latency with Impulse Reverb plugin | pennylink | Digital Recording & Computers | 2 | 07-22-2005 10:22 |
| recording guitar latency | beefeater267 | Recording Techniques | 3 | 01-27-2005 11:55 |
| does sirs latency demands affert buss send quality of reverb | lopie | Cakewalk / Sonar Forum | 2 | 02-25-2004 07:13 |
