Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 01-10-2009
madfresh madfresh is offline
Newbie
madfresh is on a distinguished road
Tempo of imported file changes to project tempo
What's up everybody.
I need your help. I'm working on a coursework at university where I have to compress samples in Cubase SX 3, but I got a problem. When I imported the files I wanna compress (Wave), the tempo of each file changes to the tempo of the project which is set to 120 bpm by default. So, what I hear is a file usually sped up a lot.
I tried to solve this problem by going into the Sample Editor, checking the tempo of the file (for instance 57.85 bpm) and then changing the project tempo from 120 to 57.85 bpm. This makes the file play in its correct tempo, however, the quality does not sound as good as the original file. It sounds like it has been poorly timestretched or something...Sounds a bit mechanic.
Before importing all the files, I have edited them in Acid. I suspect that maybe this can have something to do with the problem....In any case, is there anyone who knows what I could do to solve it?
Thanks!
Old 01-11-2009
Newbie
Come on, now!
Old 01-13-2009
Waffleness's Avatar
Waffleness Waffleness is offline
www.waffleness.co.uk
Waffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond reputeWaffleness has a reputation beyond repute
I remember SX3 doing this when I used it. I cant remember exactly how i fixed it, but there is some kind of "auto tempo" matching option that will either match the sample rate of the audio, or the tempo...
I would start by making sure the sample you have imported is playing at the same sample rate as everything else (start with 44.1k). Then just play with the import and tempo matching settings... cant think what else to suggest. I know you can fix it .
Change tempo of a imported song on Sonar 6 Producers Edition Cudmasters Los Cakewalk / Sonar Forum 4 03-18-2008 05:18
Slowing down tempo of wav file GoVols Cubase User Forum 7 01-14-2008 20:46
Loop Tempo Sync with MIDI Tempo tdukex Sony Tools / Sonic Foundry 2 01-05-2003 18:20
Matching up rhythm/tempo of imported wav files DMBean83 Cakewalk / Sonar Forum 9 09-24-2002 17:32
help! imported audio tempo mismatch gamma ray Cakewalk / Sonar Forum 3 03-18-2002 05:50
