Old 01-06-2009
Deaaaath Deaaaath is offline
Junior Member
Deaaaath is on a distinguished road
Help-- trouble with Tascam 38
So I got my Tascam 38 fully serviced at the end of August, and everything was working great until late November. After threading the tape and pushing play, the Shut off arm and pinch roller would engage as usual, but the tape would not move-- I believe the capstan shaft would not engage as per usual because even when simply lifting the shut off arm, I wouldn't hear the usual hum of the motors working. Anyways, Fast forward and rewind still worked fine; just no play. I would disengage and the shut off arm, re-engage it, and after a few fast forwards and rewinds, eventually the tape would play and all would be fine. I probably should have taken it in to get looked at at this point, but money, of course, is an issue. This problem persisted, and eventually I would just get the tape to play by pushing the play button and then manually starting up the reel with my hands. Tonight, not even that would work. Half way through writing this, it occurred to me to take a video of the problem.
http://smg.photobucket.com/albums/v2...=tascamwoe.flv
If anyone has any advice, even if it's just "Bring it in for professional repair" I would really appreciate it. Thanks.
Old 01-07-2009
mastercontrolme's Avatar
mastercontrolme mastercontrolme is offline
Senior Member
mastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond reputemastercontrolme has a reputation beyond repute
Hmmm, almost looks like the brakes are not releasing. Maybe it's the brake solenoid? Does the pinch roller engage completly or does it get stuck?
EDIT: Maybe there are some dirty contacts somewhere, or the signal is not being sent to disengage the brakes on play, I don't think it's anything serious, but you may need to get it diagnosed by a pro.
Old 01-07-2009
sweetbeats's Avatar
sweetbeats sweetbeats is offline
Reel deep thoughts...
sweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond reputesweetbeats has a reputation beyond repute
Huh, huh annnnnd huh!
Thanks for putting up the video. That is relly an effective way of presenting a problem.
SO...
  1. Is the capstan shaft spinning?
  2. Can you do what you're doing and manually encourage the supply reel at all or are the reel motors dead?
  3. Didja check your fuses (and I mean with a multimeter...check for continuity from pole to pole on those fuses)?
  4. What happens if you leave the reels off and manually raise the tension arm and hit play?
  5. It looks like the 30-series use the same rubber "cushion" washers between the body of the solenoid and the solenoid shaft...keeps them things from clacking something awful when the solenoid shaft retracts. Anyway, they can get sticky and turn to goo. Can you check those out? I can give you more specifics if needed. They're not hard to get to...
Old 01-07-2009
Senior Member
SO...
Good point about the solenoid cushion. I had to remove the one on the brake solenoid in my 42 as it did not seem to be retracting enough to release the brakes fully causing a drag. I removed this felt and it's now fine, just a little noisier.
Old 01-07-2009
Junior Member
SO...
1. No, it is not spinning.
2. Up until last night I could start the reels by manually winding them when in play. Now when I do that it plays super slow for a second and then slowly fades to a stop.
3. I haven't checked the fuses, nor do I think I really could haha.
4. I haven't done that specifically yet (I will later), but I can tell you that when I leave the reels off and manually raise the tension arm, the capstan shaft does not start to spin like it used to.
5. Very interesting! Unfortunately I don't know how to check for this... could you give me some directions if possible?
thanks so much!
Old 01-07-2009
sweetbeats's Avatar
I would check the fuses before doing anything else. Do you have or can you get a simple multimeter that will test for continuity? Even one of the cheapy ones ($10 ~ $15) will do...
Do you have a full manual for the deck?
Old 01-07-2009
Junior Member
Yeah, I have the full manual.
I can get a multimeter from a friend I think. Will checking the fuses be a simple enough process? I am pretty empty on knowledge in regards to that stuff haha.
Old 01-07-2009
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
First thing I would look at is the capstan belt.
Old 01-07-2009
sweetbeats's Avatar
It looks like the fuse board is likely on top of the supply reel motor housing. Can anybody confirm or disconfirm that? I don't have a 38 service manual but I have the 32 service manual and that's what it shows.
Disconnect the 38 from its power source (i.e. unplug the thing) but leave it switched on. This will help to drain residual power from the guts.
Deaaaath, you'll have to get the "Bonnet Panel" off...that's the one that goes around the top and sides. If it is like the 32, there are 7 screws that hold the upper "Rear Panel" on. Take those off, and then there are 3 screws on each side of the deck...take those out and you should be able to get the Bonnet Panel off. See below.
Borrow the multimeter from your friend and have him show you how to test for continuity. You'll set it to continuity and then you'll put one probe on one side of the fuse, and the other probe on the other to see if the fuse will pass electricity (yes you could just look at the fuses, but sometimes they may not look blown when they are). If they are all good, rotate each one in its fuse holder in case there is oxidation. If it still doesn't work then we'll go from there. If any fuses are bad, rotate the good ones, take out the bad one(s) and bring it/them to your local electronics shop. Get several replacements in case it blows again when you put the good one in the deck. If it/they do blow again then its a bigger problem that will likely require a repair tech.
Keep us posted.
Old 01-07-2009
Junior Member
Sweetbeats, thanks so much for bearing with me and giving such detailed responses! They've been very, very helpful.
I'll borrow the multimeter later today/tonight and let you know how it goes. Hopefully we'll figure something out!
Old 01-07-2009
poopchute's Avatar
poopchute poopchute is offline
Just back from your moms.
poopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond reputepoopchute has a reputation beyond repute
Just incase...I do have alot of spare internal parts for a 38. From the fuse block to the brakes and just about all the internals. So if you need anything I could help out...
I own: Tascam TSR-8, Tascam M-30.
Im on the lookout for a nice Tascam M-1516...
"I sell drawings of the recording at the gigs on homemade paper."-zorf
  #12
Old 01-07-2009
cjacek's Avatar
cjacek cjacek is online now
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
I would also suggest you look at the capstan belt, as Herm suggested. It can be off or slipping or it has additionally turned to goo and has gummed up the capstan motor shaft [as you mentioned you can't hear it, right?]. If it's the belt then it would easily explain your problem.
  #13
Old 01-07-2009
sweetbeats's Avatar
Yeah...right-right-right...Deaaaath, you'll be able to see that stuff (I think) when you take the upper "Rear Panel" off...I totally missed Herm's suggestion about that.
The possibility of a toasted capstan belt being the cause could be reinforced when you test what happens with the deck unloaded (no tape). Again, if you manually raise the takeup tension arm and hit PLAY, the supply reel table should spin madly in a clockwise fashion, and as you slowly lower the takeup tension arm the takeup reel table should spin up (right, guys? ). If that happens then I'd bet Herm and cjacek are right that the belt is bad. It would also explain why the problem didn't happen instantly right? It came on gradually?
  #14
Old 01-07-2009
Junior Member
I did this about five minutes ago. Raising the take-up arm and hitting play caused both reel tables to spin madly, and they both came to a stop when I lowered the take-up arm. Is this reinforcing the bad capstan belt idea?
Yes, the problem came on gradually, and only came to this totally useless point after a month or so of gradual decline.
Can I access the belt by taking off the FRONT panel like my intuition (which is usually pretty worthless) tells me or through the upper REAR panel like sweetbeats said?
  #15
Old 01-07-2009
cjacek's Avatar
Analogue Enthusiast
Looks like it's a bad belt...
If the 30 series is all the same [and as my 34] then you gain access from the front panel. I'm actually gonna try to find a link where I changed the belt on my 34, if it would help you. Hold on...
  #16
Old 01-07-2009
cjacek's Avatar
Analogue Enthusiast
Here: http://homerecording.com/bbs/showthread.php?t=238939
  #17
Old 01-07-2009
Junior Member
Cjacek, thank you! I'm heading out to borrow some wrenches from a friend, and then I'll open up the 38.
  #18
Old 01-08-2009
sweetbeats's Avatar
Oooo nice work, Daniel. That's right...you helped johnbilben out with his 38 capstan belt issue.
Thanks for correcting my hunch on the access point.
Deaaaath, you can do it! I think johnbilben had about the same experience and comfort level as you and he tackled it and everything worked out great with cjacek's help, so there's a bit of encouragement for ya.
I love it when a plan comes together!!
  #19
Old 01-08-2009
jpmorris's Avatar
jpmorris jpmorris is online now
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
If it's like the 32, there will be a recessed nut underneath the varispeed knob. This pins down the front and has to be removed with a pair of pliers or something. Apart from that and removing all the knobs, rollers etc it's pretty straightforward to remove.
If memory serves, you might also have to remove the block containing the heads to get at the capstan belt. This should just be screwed in place.
  #20
Old 01-08-2009
Junior Member
Ugh yeah, that nut is being really annoying. I can't remember where I put my needlenose pliers, so I'm currently stuck on trying to remove that dang nut.
  #21
Old 01-08-2009
Junior Member
Well, I finally opened up the 38 and unfortunately (or fortunately?) didn't see anything wrong with the belt... I think I'm just gonna bite the bullet and bring it into the Tascam repair center which luckily is only ten minutes from my house!! I just wanna say thanks to everyone for all your help!! It's too bad I couldn't fix it myself, but at least now I know what the inside of my machine looks like! Maybe next time... seeing as there inevitably will be a next time
  #22
Old 01-09-2009
sweetbeats's Avatar
Bummer
Sorry to hear that, Deaaaath. Did you happen to check the fuses?
Please keep us posted. Your time and struggle is appreciated. We all learn and can help others with the info.
Check the fuses. If theya re all good I'm guessing there is a component or two that need replacing in your capstan motor. It happens.
  #23
Old 01-09-2009
RRuskin RRuskin is offline
Rick Ruskin
RRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond repute
Have you tried a new reel of tape? You could be dealing with sticky-shed and not know it.
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
  #24
Old 01-09-2009
sweetbeats's Avatar
Yeah, but he says the capstan shaft isn't spinning even with the deck unloaded.
  #25
Old 01-09-2009
Rick Ruskin
Did he check to see if the motor worked when he had the machine opened? My guess is, if it ran, the belt is too stretched/funky to get any traction. If the motor was dead, it probably has bad drive transistors. He did say the problem got gradually worse and a failing transistor will behave that way.
Rick Ruskin
Potential trouble with a Tascam 38 Deaaaath Analog Only 3 10-14-2008 10:01
tascam 38 trouble tapeboy TASCAM User Forum 11 07-06-2005 11:29
tascam 388 trouble lofipower TASCAM User Forum 0 07-22-2004 17:22
Tascam 488 Pan Trouble RoZzInet TASCAM User Forum 1 06-05-2000 22:54
Pan Trouble with Tascam 488 MKII RoZzInet Analog Only 2 06-02-2000 14:13
