Old 01-05-2009
Talldog's Avatar
Talldog Talldog is offline
Pain in the ass
Talldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond repute
Is this a good deal? MCI jh110 1/4
Local on CL.
I have on mid-eighties MCI JH110 1/4" deck for sale. 100% restored, working, aligned and in use now. I can deliver and verify alignment if desired.
Along with the pictures below, I have a video of it working and going through a 20hz-20khz frequency response test in record mode.
I can also provide you with an extensive list of things i did as part of the restoration process, including head adjustments (azimuth & wrap) tensions, resoldering connections- the list goes on and on.
-Chris
Old 01-05-2009
Talldog's Avatar
Pain in the ass
This is the list of things for the refurb.
Blow out Machine with Air Compressor
Remove Power Supply and Blow out
Clean Machine with 409 top to bottom
Lube Job Female Cinch Jones to Power Supply
Lube Job Female Cinch Jones to Audio Drawers
Resolder Pins on boards in Power Supply
Clean chips/lube job sockets on boards in Power Supply
Check voltages on Power Supply
Verify Fan operation on Power Supply
Resolder Pins on Transport Motherboard
Clean chips/lube job sockets on Transport Motherboard
Clean chips/lube job sockets on Analog Torque Board
Clean chips/lube job sockets on Phase Lock Loop Board
Lube Job female sockets on back of Analog Torque Board
Lube Job female sockets on back of Logic Board
Lube Job female sockets on back of Phase Lock Loop Board
Lube Job female sockets on back of Light Board
Resolder Pins on Audio Motherboard
Clean chips/lube job sockets on Audio Motherboard
Clean chips/lube job sockets on Audio Cards
Lube Job female sockets on Audio Cards
Plug in Power Supply for Transport Only
Verify Transport Operation and set Tensions
Plug in Power Supply for Audio Drawers and load Audio Drawers
Check input/record/reproduce
Troubleshoot
Do rough alignment
Check bias
Check azimuth
Check tensions
Do Final Alignment
Old 01-05-2009
RRuskin RRuskin is offline
Rick Ruskin
RRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond repute
It sounds as if it is a clean machine. How much is he asking for it?
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
Old 01-05-2009
Talldog's Avatar
Pain in the ass
OOPs. Should have put that in. He's asking $800. He will bring it to Cleveland from Nashville himself and make sure it is up to spec.
Old 01-05-2009
Rick Ruskin
Sounds like a good deal to me.
Rick Ruskin
good deal? tom18222 Digital Recording & Computers 5 09-19-2007 04:19
Was this a good deal? bigwillz24 Digital Recording & Computers 2 12-17-2006 20:04
Ever wonder if you're getting a good deal? Michael Jones The Rack 7 08-23-2003 20:40
Good Deal? or Rip Off? alexspetty Keyboards and Sound Modules 5 02-04-2003 20:56
Is this a good deal? hokypokynose Mixing / Mastering 3 01-18-2002 22:53
