Adding More inputs/outputs to Pro Tools LE rig
So i'm in the market for getting more inputs and outputs for my pro tools rig. I was thinking of getting a presonus pre amp that i can connect to my mbox 2 via S/PDIF. I think you can do that. i'm not positive though. But I would also like to have more than just 10 channels but i don't feel like buying a mixer. Can you attach mic pre's to each other and then to the mbox like a daisy chain?
you won't be able to get 10 channels into an Mbox2. it maxes out at 4. 2 through the analog inputs and 2 through spdif.
even the mbox2 pro only goes to 6. spdif is a 2 channel only format so if are to get a preamp with a built in converter you are better off sticking to something with only 2 preamps. there are lots of ways to do this. the ART DMPA or apogee mini-me are a couple of decent ways. also something like the M-audio Tampa has 2 channels of conversion built in but only one preamp which would allow you to use the second channel for the preamp of your choice. if you want 10 channels(or more) you will have to step you to a DIGI002 or 003 |
I started off with an Mbox and then moved to a Digi 002R. I like the 002R a lot better in every respect.
http://www.misterpotts.com |
oh really, wow i did not know all of this. I was told mbox 2 had better pre amps than the digi 002 because it was newer. so if i wanted more channels i would need t go to atleast digi 002? hmm Thanks!
as far as the number of inputs its right there in the specs with the hardware mbox2 4 input mbox2 pro 6 input 003/003r 18 input |
The 003/003R was not yet available when I bought my 002R. I don't use it's preamps, so I really can't say how they sound. However, overall I'm happy with how the unit sounds otherwise.
| adding inputs for Pro Tools LE | jimmycs780 | Newbies | 1 | 01-01-2007 22:21 |
| inputs/outputs ? | 1_mic | Cool Edit Pro / Adobe Audition Forum | 3 | 06-09-2004 01:53 |
| inputs and outputs | guitarfreak12 | Other Equipment and Reviews | 2 | 06-04-2004 09:49 |
| Tape Inputs and Outputs | HSlaton | Newbies | 0 | 07-05-2001 05:38 |
| 24 inputs 24 outputs DAW | beatleme | Digital Recording & Computers | 0 | 09-13-2000 17:13 |
