Alesis IO/2, Windows XP, Cubase
Hello All,
I am totally new to recording. I have windows xp, an ALESIS I/O 2 interface and cubase. Can anyone advise as to what the optimum setting within cubase device set-up are for this interface? Best Matt |
Thats an odd question to be sure! Whattya mean exactly? If you're using the alesis drivers you shouldn't go far wrong...experiment with latency buffers.
buffers
Hello,
thank you for your reply. Yes, I meant buffers. Is there an optimum input/output latency in terms of ms. And I am intrigued to know how tracks are synced up. For example if I play guitar and record along with a drum track, the tracks sync up perfectly in terms of timing. Does this syncing up happen within the io/2 or does cubase do it? I would like to know how the signal flows into and out of the io/2 interface. Best Matt |
there's no way any of us can tell you how to set your bufrfers it's too system dependent... and cubase does all the work...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Cubase does the work
Hi,
Thanks for the info. I will fiddle around in Cubase to get the best results. So am I right in thinking that it doesn't matter if there is a bit of latency because cubase matches the tracks up anyway? How does it do this? I would very much like to know. And should I be recording at 41 or 48 thousand mega hz? Thank you for your patience in answering. Best Matt |
Latency refers to a delay in the processed output sound only; the time it takes for the computer to receive your inputted audio, process it, add any effects (VST plug-ins for example) and output it again. So latency causes a delay in monioring your soun which is, understandably, annoying when it comes to playing with a drum track. But the unprocessed sound is being recorded in real time - you're just not aware of it unless you enable Direct Monitoring.
bit rate
Hi there,
Thanks for your kind help. How do I adjust the bit rate? Best Matt |
| Does Cubase SX-3 or Cubase 4 work on windows Vista? | Singhy | Cubase User Forum | 8 | 10-04-2007 19:13 |
| FS: Cubase SX 1.0 (Mac OS X/Windows) | dgatwood | Free Ads for Music / Recording Equipment | 4 | 05-04-2006 22:35 |
| Cubase LE and Windows 98 | PYRRHO | Cubase User Forum | 3 | 02-17-2006 17:15 |
| alesis serial driver for Windows XP | shackx2 | Alesis Forum | 0 | 03-14-2002 19:19 |
| Cubase VST 24 And Windows NT | ummhello1 | Cubase User Forum | 2 | 03-09-2000 12:12 |
