Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-18-2008
Toddskins Toddskins is offline
Dedicated Member
Toddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond reputeToddskins has a reputation beyond repute
Kurzweil K programming help needed
I cannot figure out how to assign a Note number to my foot continuous controller from Setup mode.
Looking in the manual, if I enter "37" from the numeric keypad into the value for the continuous controller 1 while in Setup mode, that assigns "KeyNum" for the destination. Fine. But then how do I tell it which KeyNum to use?
I'm trying to trigger notes on my keyboard from the continuous controller, similar to how you can do so from any of the 4 foot pedal inputs (i.e. Note momentary, or Note toggle).
I have tried assigning the destination to CC1 as the foot pedal3 which I programmed to be Note momentary, but that logic did not work.
I realize that when I move my CC1 pedal past the half-way point, that I want it to trigger a certain note at that point, but do not know how to further program the CC1 KeyNum parameter.
Help please.
Old 12-19-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
not sure you can do this... as i understand it... with a cc port what you have is a voltage supplied ro a pot... the sweep then is sent to the controll line... when the port is assigned to a parameter the @change applied to the parameter is then proportional to the point the sweep is at... make sense??? so the port might only be at the trigger #in passing and not trigger...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 01-02-2009
Dedicated Member
You are right
Thanks. I took your answer and confirmed it on a Kurzweil user group site.
'Appreciate your response.
programming reason musicman23 Newbies 1 10-10-2008 01:30
help needed:Kurzweil KSP-8+Samplitude+Lynx violindave Mixing / Mastering 4 03-30-2006 09:52
Programming? a modified dog Newbies 4 04-24-2001 13:13
