Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 12-16-2008
crgl crgl is offline
Junior Member
crgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant future
Whats the main difference with guitar single effect unit and multi-effects ?
What I wanted to know is if it is true that most guitar multi-effects units handle the signal digitally including distortion.
I know that many guitar effects are done digitally like delay but
I also know that distortion and overdrive are done with analog
circuitry (?), transistors, etc.
But in multi-effects units the distortion and overdrive effects are almost
always done digitally.
Is there a real difference in sound between the two ?
What is the convenience of one over the other?
like analog overdrive over digital overdrive?
Old 12-16-2008
bassbrad's Avatar
bassbrad bassbrad is offline
Newbie
bassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond reputebassbrad has a reputation beyond repute
Yes they are digital but the current units are using modeling and actually sound pretty good and accurate to the original. There is a slight sound quality difference and usually more control on the analog, so if you have the actual analog device that would be preferred, if not how cool is it to have digital models to create your sounds.
Old 12-16-2008
Junior Member
do you know which other single effect pedals are analog apart from overdrive and distortion ?
Old 12-16-2008
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Just about anything could be analog, other than samplers and loop pedals. Most often, however, time domain effects (delays, reverbs, chorus, flangers, harmonizers, etc.) are best handled by digital, and most other stuff is best handled analog - that's a generalization if course, but not an unreasonable one. Obviously there are exceptions, such as TC Electronic's excellent analog chorus pedal, but they usually just go to prove the rule.
Personally, the biggest advantage I can see to stand alone effects is that they can be designed to do one thing really well, instead of many things fairly well. If you want a unit that does everything really well, you are looking at a VERY large chunk of change, and even then I'd rather have separate units.
Of course, at the moment the only non-amp effect I'm using is my Boss delay pedal, and if I didn't need it so much I wouldn't even be using that, so I guess my view on effects is a bit on the hide bound side.
Light
"Cowards can never be moral."
M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children."
-Aqeela Sherrills
http://www.theforgivenessproject.com/
Old 12-17-2008
Sonixx's Avatar
Sonixx Sonixx is offline
1K Silver Member
Sonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond repute
for an all-in-one box, have you checked the AXE-FX. it's pretty much the Cadillac right now.
Clips...
Old 12-17-2008
wbcsound's Avatar
wbcsound wbcsound is offline
Senior Member
wbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond repute
The biggest draw back to using multi-fx units is you are bound to that companies interpretation of a given effect. So whila unit might do delay and chorus very well, the distortion sound may be mediocre or vice versa. Individual pedals allow you to mix units by different manufacturers to really fine tune the sounds you want.That being said, I find pretty much all the current generation of fx units are capable of some good tones.
The biggest advantage of multi-fx units is the ability to perform complex switching on the fly.
Old 12-17-2008
Gear_Junky's Avatar
Gear_Junky Gear_Junky is offline
The SCXD Defender
Gear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond repute
I once had a MIJ Boss DM-2 Analog Delay (I also had DM-3 at the same time, but liked DM-2 better). This was in the late 90's. And I also had a modern MIK digital delay (also Boss, DD-5 maybe, if I recall). I didn't know much about effects, but the DM-2 echo was SO sweet sounding.
I got to the point where I had a full pedalboard of stompboxes, including noise gate. Pedals were mostly Boss, except a Tech 21 XXL overdrive and a wah. What I didn't have was tone
I always thought I tend to prefer good analog effects, but too many pedals together just end up degrading your signal.
I thought I'd never like anything digital, especially overdrives/distortions. Even expressed my doubts to a guy reviewing the Fender Super Champ XD (digital preamp, including digital amp models, digital effects, Class A/B tube power section). I ended up getting the SCXD amp and I really like the cleans, some of the overdrives, the simulated spring reverb, the tremolo, the echo.
Maybe it's not quite the same as a tube-driven reverb or a tremolo in a vintage amp, but I like having everything in one box, with not much noise added.
I might still end up getting a pedal for tremolo and a pedal for compression, so I can stick with using the amp's reverb, but I never want another huge pedalboard.
Disclaimer: I don't record
I am a musician trapped in a lazy bum's body
Old 12-17-2008
Junior Member
Thanks for all your responses.
From what you said this are the pros of analog or single unit effects:
Pros:
-versatility of using the effects of your choice
-generally, more control
Cons:
-many pedals can degrade signal
Multi effects
Pros:
-allow complex switching on the fly
-signal handled digitally...more clean
Cons:
-you are bound to the effects in the unit
-effects are more limited
Old 12-18-2008
Gear_Junky's Avatar
The SCXD Defender
and don't forget that some analog effects sound better than some digital.
some even sound better than any digital.
Pros:
Cons:
Multi effects
Pros:
Cons:
Old 12-18-2008
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
Also a major difference would be true bypass if no one had previously mentioned this. A lot of the better single pedals have this, most multi effects would probably not as far as I know
Peter Miller
Old 12-18-2008
wbcsound's Avatar
Senior Member
I would say this is a matter of opinion and subject to individual taste rather than a general strength or weakness.
I think you'll see Boss pedals on the boards of countless pros who's tones have been lusted after by millions. True Bypass would be absolutely last on my list. Trust your ears. If it sounds good it is good.
  #12
Old 12-21-2008
Ed Dixon Ed Dixon is offline
1K Silver Member
Ed Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond repute
Like guitars and anything else, it’s a matter of personal opinion. I’ve done the single effects route, the rack effects route, and the single digital pedal board route. All things considered, I like the digital pedal board. I use a POD XT Live and love it.
Ed
  #13
Old 12-21-2008
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Pros:
Cons:
Multi effects
Pros:
Cons:
A multi-con -poor direct access to parameters. (from one who constantly wants to dick with the 'tone in the middle of the gig.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Looking for a reverb unit and/or multi effect box Magnum Pi The Rack 53 07-16-2007 00:38
Multi-effect/mic/single effect on 2488 mandpasbury TASCAM User Forum 2 02-21-2006 08:58
for sale: lexicon alex multi effect unit maskedman72 Free Ads for Music / Recording Equipment 1 04-13-2004 18:51
Need a REALLY good multi-effects and/or Reverb rack unit for live guitar... pisces7378 Guitars and Basses 14 04-25-2003 04:34
Need a REALLY good multi-effects and/or Reverb rack unit for live guitar... pisces7378 The Rack 9 04-22-2003 13:55
