Yet another Preamp Question
I've read and read about the importance of preamps.
I came across a thread where a guy wanted to "match the quality of the preamps in his firepod" I use a firepod and was looking for Preamps to add to the mix would an additional preamp make that much of a difference? i know there are 10000's of variables are the firepods preamps as good as/ better than/ worse than cheap external pre's.. behr, art? |
Sincerely -Someone just like you (haha) -Barrett |
Post a question here about which preamp someone prefers, and you'll get as many opinions as there are users on the board.
![]() Adding an inexpensive ART preamp in the front of your chain will likely bring you very similar results to what you're getting right now. PreSonus, ART, Behringer, etc. all make similar entry-level preamp boxes. The next step up would be a mid-level model from Focusrite, UA, or Trident. Then you've got the big-boy toys like Manley's, and Avalon's. To answer your question... yes, PreSonus, ART, and Behringer are all on the same general level. Better/worse is in the ear of the beholder. |
my main question is.. I allready have the firepod and a mackie 1604 pro..
is there any "gain" no pun intended, in sound quality, by purchasing an entry level or under $500 preamp? Or should i focus on better mics? I know these are all addressed elsewhere but not in relation to the Preamps i have in the firepod |
You might try one, , record the same take to both and compare them. They should be the same take' (maybe split a mic) and be at exactly the same volume. Send it back if the difference isn't worth it.
Likely the dif. will be significantly less than leaning in on the mic two inches. ![]()
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
)Joking aside, what type of mic's are you using now? (hard to suggest an upgrade if we don't know what you're using) |
finally
that makes me feel better, so the Pres in the firepod are equivilant,or better than, an external behr or cheaper piece of art gear right? i use a 57 on snare, akg112 on the kick, and i know my overheads need an upgrade but there mxl pencils.. cheap... on the toms i have the audix f series but i tend to keep them pretty low in the mix when i record guitar i use a 57 vocals, which i rarely record , i use a neuman when my friend lets me borrow it, other wise its a perception P.O.S. again thanks for the help to all!!!!!!!!! |
about the room treatments
I have a 12' by 12' room, "daddy's band room" as the kids call it. The walls are not attached to the rest of the house to avoid tranferring sound energy, and a double layer of sheetrock installed to help tame the lows. Heavy carpeted floor with a thick pad, on concrete. And those cheap 3" "eggcrate" style foam 12" x12" square pads mounted randomly on the walls and ceiling to avoid major reflection issues. The room is pretty "dead". The ceiling is angled on two sides, about a 25 degree towards the floor, |
| newbie preamp question.Good preamp that match the FW1884? | Electricsun | TASCAM User Forum | 0 | 12-22-2007 09:14 |
| Mic Preamp question... | Tyler22 | Microphones | 4 | 01-10-2007 16:47 |
| signal chain question- preamp>mixer>sound card or preamp>soundcard? | iamme | Newbies | 2 | 05-25-2006 02:47 |
| mic>preamp question.. | Sanjanjoseph | The Rack | 0 | 04-10-2005 20:04 |
| Preamp question | The Pianoman | Newbies | 3 | 01-29-2003 00:08 |
