What is a Direct Box for ?
Excuse my ignorance, but I see this DI box again and again
and don't really understand what it is used for. Right now I record my guitar direct through a Boss GS-10 guitar effects and amp simmulator to hard disk recording in my Alesis Fusion keyboard which has 8 audio tracks. It is not the most natural sound but at least neighbors don't have to complain. Is this DI box something you can put between the guitar and the amp? or between the amp effects amp sim and digital recording media? Does it enhance the guitar sound ? Thanks. |
A DI or "direct injection" box is an impedance (load) matching device used between two devices. In the case of powered DI's the box may actually bump up the incoming signal to line level. Typical uses are between bass guitar and console, from and amplifier line out to XLR lo impedance.
"Who's that singing? That can't be me, I don't sound like that." |
If I am recording direct, guitar, keyboard, bass, or whatever, there is usually some noise from the source. It may be very light, but over several tracks it can add up. So to keep the tracks whisper quiet, I run the instrument through the Radial JDI direct box, and all the unwanted noise is gone. I do not look for the JDI to enhance the sound of the instrument, just keep unwanted noise out.
Charlie |
DI converts unbalanced high z signal into a balanced low z signal
a 1/4" TS to male XLR transformer will do the same thing and takes up a whole lot less space than a DI box. |
A transformer may sub for a DI in some, but not all, applications. |
A DI, ideally, will not enhance the sound of whatever is plugged into it. DIs are to be invisible soundwise, but as with all things a DI will perhaps cause subtle changes to the sound - hopefully pleasant changes. It sounds as though you are using the GS-10 as a DI in your setup.
Belief does not create truth. Disbelief does not destroy truth. |
And, when not being used as a recording device, a good DI box will also do service as a handy dandy doorstop. Behringer is particularly good for this.
They're also good for leaving on the floor in random places so people stub their toes on them or trip over them. I don't know how I lived without one.. ![]() |
It only use 2 of its outputs: 1 stereo line output 1 mono amp output It doesn't have a balanced output so I don't think it qualifies as a DI box. This is my setting: Guitar >>> Boss GS-10 >>> Digital Recorder in my Alesis Fusion Keyboard I wanted to know what is the usefulness of the DI Box in a guitar setting. |
With electric guitar, not much, IMO. The amp and speaker(s) play so much of a part in the sound that mics are the way to go (IMO again) to get the signal into recording and performance systems. For acoustic guitar, keyboards and (maybe) bass, they are very useful.
I posted: A transformer will sub for a DI in most, but not all, applications. You posted: A transformer will sub for a DI in most applications, but not all, applications. That's not correct. What I posted was correct, though it was a little stilted. I could remove all the commas: A transformer will sub for a DI in most but not all applications. Or maybe use a set of parentheses: A transformer will sub for a DI in most (but not all) applications. But what I really meant to convey was: A transformer will not sub for a DI in all applications. ;^) |
#12
"DI converts unbalanced high z signal into a balanced low z signal a 1/4" TS to male XLR transformer will do the same thing and takes up a whole lot less space than a DI box". A DI Box transforms an unbalanced high Z signal to a balanced low z signal signal an inline transformer does exactly the same thing and most people use one or the other mostly for that purpose. So what part of what I said is wrong? ![]() |
#13
Certainly, a transformer will do the same thing as a DI box as long as all you want to do is convert Hi-Z to Low-Z; open up a passive DI box, and you'll find a transformer just like the ones in the inline case. However, it will not split your signal if you want to send to an onstage amp as well as into the snake. It won't allow you to lift the ground on the balanced side if your connection results in a ground loop. It won't boost the signal from a low output passive acoustic guitar pickup like an active DI will. I have a handful of transformers and some DI's as well; sometimes an inline transformer will do the job I need done, sometimes it won't. I use the right tool for the job; space, either onstage or in my gig case, isn't really a consideration. |
#14
I plug guitars, basses, tape decks, RtRs, mics, everything directly into the Firepod.
[SIGPIC][/SIGPIC]Instant Karma tried to get me... and succeeded |
#15
YES to mic'ing your amp. And YES to keys and bass. But NO, I don't agree about using DI for acoustic guitar. An acoustic's body is it's "amp." Using a pickup bypasses so much of the "tone" the body gives the guitar- and although that applies to some pups more than others (the Fishman- yes, Fishman- piezo I installed on my Martin has almost no tone, compared to the guitar's body) they all basically suck, in comparison to a well-mic'ed acoustic. But, my GOD, ALL of my acoustics have such different voices- the cut-thru-the-mix quality of my Martin D-16, the mellow-cedar-top Seagull, the Wow-where-did-all-those-over-and-undertones-COME-from? Arbor 12-string (Yes, Arbor! That 12 has more interesting o-and-u-tones than any other 12 I have ever heard), the thin-and-tite Harmony Tenor... I just can not IMAGINE choking them thru a pickup. Now, for the above, I am assuming we are talking about recording. For live sound, where the space or room can pretty well F- up all your well-intentioned attention to tone, I think acoustic pickups and DI boxes- on electrics, too- are the way to go, so you can concentrate on the performance and not worry about staying close enough to the mic, having one more piece in the sound chain from your electric guitar/amp, etc. JMHO... |
#16
Ok
Im gonna jump in and ask some perhaps obvious questions. In my situation I record thru a tapco usb interface that has instrument and line level selection options Would this be a built in DI? secondly when playing a passive pickuped instrument plugged into my Behringer eurorack mixer would a DI improve the quality of this connection ? The Mixer has xlr and balanced or unbalanced trs connections for inputs so Is an impedance matchingdevice nessesary or benificial? Thanks heaps P |
#17
I browsed through the responses quickly so if I missed it I am sorry. I was surprised that no one mentioned Re-amping. I do some of the tracking for my band but it is typically mixed by a pro-engineer in a pro studio. I always have a direct track running with my guitar tracks. This way if a tone doesn't work out, we just re-amp it in the studio and find something that does. This would be Impossible (to my knowledge) without having the direct tracks taken off the direct box. |
#18
the mixer should also have a TRS input for instruments like keyboards which is also a balanced input. Quote:
with High Z signals anything longer than 20' the signal starts to diminish. in a recording situation i seriously doubt you will have that problem. the biggest problem you will have to contend with is line noises coming from other electrical currents being supplied to lights or other appliances. the biggest noise problem I have to deal with in the studio is the line noise emitted from fluorescent lighting however when the lights are turned off the noise stops. |
#19
#20
| Besides a direct box..... | stinkfish | Recording Techniques | 5 | 11-10-2005 10:46 |
| Direct In Bass w/ Hi-Z Input: Need a direct box? | joshw | Guitars and Basses | 2 | 07-03-2005 18:36 |
| direct box with GT-6? | distortedrumble | Recording Techniques | 1 | 11-15-2003 19:59 |
| Direct Pro LX6 | nenor | Digital Recording & Computers | 6 | 02-02-2003 02:42 |
| Direct X??? | MiXit-G | Cubase User Forum | 6 | 12-09-2001 20:03 |
