Old 12-10-2008
diRegRemo diRegRemo is offline
Registered User
diRegRemo is on a distinguished road
Compression Question #2
I have my compressor last in the chain before the interface. The compressor has a +4/ -10 button on the back. My mixer has the same buttons beside the channel controls. Does anyone know what these buttons are for, and how they work together; if they work together. Also why the hell is my compressor causing a buzz sound. Not there when I turn it off, but comes back when i turn it on and sing. could it possibly be the cable or the connector?
Old 12-10-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
1) I can't recommend enough removing the compressor from the input chain. There's no "undo" on a compressor and 9 out of 10 times (IME) it's being improperly used, throwing the input gain staging into a tizzy.
2) +4 is balanced, -10 is unbalanced. If you're running a completely balanced chain then everything should be at +4 (look in your manuals).
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Compression/Pre Amp Question guitar zero The Rack 8 03-08-2008 10:30
One question for compression. Rhamett The Rack 9 12-15-2006 10:23
Compression question? fiveironguy Other Equipment and Reviews 14 01-26-2006 00:55
question about compression Tyler22 Recording Techniques 5 06-14-2004 13:25
compression question dick west Mixing / Mastering 13 01-05-2002 22:46
