Old 12-10-2008
eddie21leeds eddie21leeds is offline
Registered User
eddie21leeds is on a distinguished road
midi help needed
hello to all this is my first post...
ok so ive been getting in to pc music production for a while and rolled out some half decent stuff with fruityloops (i actually started doing a proper cubase course at college but it lost me!) i am happy using fruityloops but i have come across my first problem and so am looking for help. basically i need to know how to play back midi files... ive changed the port number via LSD to 0 - matching all of the midi ones to no avail... ive enabled midi output... what am i missing?? thanks in advance for you patience with a n00b!!!
Old 12-11-2008
blazingstrings's Avatar
blazingstrings blazingstrings is offline
dgatwood can **** himself
blazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond reputeblazingstrings has a reputation beyond repute
A listing of gear and software you use would be helpful......
Analog! Shmanalog! I want my Digimon!....... Oh! thats were my hand was!
Old 12-12-2008
Registered User
ok... sorry. i am running fruityloops 5 on a standard pc / standard soundcard no special hardware or anything, when i import a midi file there is no sound. thanks!!
Old 12-12-2008
solaris1982 solaris1982 is offline
I wish I had skills...
solaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond reputesolaris1982 has a reputation beyond repute
MIDI in and of itself is soundless...for lack of a better term, it's basically a string of code that tells a computer what to do. You have to have something on the track for the MIDI to play (a sampler for example).
Are there any virtual instruments on the track you're running the MIDI to?
Old 12-12-2008
Registered User
im afraid im a bit of a beginner - do i need to somehow route it through the "mixing desk"? i have put the fruity LSD on to channel one and its flashing as if there is somthing there and i've changed the port to 0 to coorespond... does that make sense? i saw it on a tutorial on youtube but mine didnt work... thanks again.
Old 12-14-2008
First are you using a keyboard to control this all or what?
Second it shouldn't be that hard if your just trying to play notes in.
Third No you really shouldn't need a mixer to use FL.....
Fourth you should be able to just drag and drop the MIDI File into a track with a softsynth on it and have it play back.......
You may wish to get a book on MIDI and Softsynths.
Old 12-15-2008
Registered User
it's just my P.C. no keyboard or anything - i'm using ready made midi files. do you have to do anything to your soundcard? i was thinking this may be the problem?
Old 12-20-2008
No you shouldn't..... Since the sounds are coming from you software the built in MIDI ports shouldn't have any bearing on it at all. Do you have your built in sound setup in FL?
Old 12-24-2008
Registered User
i'm not sure.... ?
Reaper ~ MIDI help needed gecko zzed Don't Fear The Reaper 3 03-18-2008 12:54
MIDI help needed! rythefly MIDI Mania 7 09-28-2004 05:07
MIDI and Soundfont help needed. pdlstl Cakewalk / Sonar Forum 6 01-14-2004 05:33
Newbe help needed Midi mike628 Cakewalk / Sonar Forum 5 10-31-2003 13:06
Newbie help needed with MIDI bigmedia Cakewalk / Sonar Forum 6 06-23-2003 04:44
