rd700sx eq settings
hi, i've been monkeying with my roland for a few months now and what i've tried from the manual doesn't seem to work.
is there any way to lock in my eq settings to a patch? every time i turn the thing on, i have to put the eq back to where i want it. i tried doing the setup assign thing, and even changed "setup" to "system" in edit mode. i get the little "eq" icon on the screen, but when i turn on the eq it shows up flat. ![]()
dross |
I dont mean to sound negative or weird but maybe you dont really need eq on the roland and your problems are else where ie; the desk or DI. I hardly ever use the eq on my roland and when I do its only mid gig when i need either more depth or more clarity and I only increase the frequencies I want by a few a Db and a half. So maybe if you kept a permenant EQ on the desk or the DI your going into that would help.
My 2 Pence Aviv |
dross |
When you do the setup, does it appear that when you store/write it, that it really does it? Do you get the message "Are you sure?" during the write process, followed by, "Writing...."? Have you been able to save any changes in setups not related to the EQ? I can't see in the manual where it would clearly say EQ can be saved, but it makes sense if it's part of a setup.
I don't have an RD-700. Your post caught my eye and I downloaded the manual. |
thanks for the effort--i really appreciate it.
dross |
I spent a couple of minutes trawling through the net and what not, :S
It seems like a mistery, but I hope all goes well. And use your ear! If its a simple case of boosting because the amp is shoddy and you want to cut through Id boost the 2-3k up a bit. Good Luck Mate |
| Roland RD300SX and RD700SX | washingtonhtsny | Other Equipment and Reviews | 0 | 03-22-2005 20:52 |
| DMA Settings in PC DAW | SongwriterCM | Digital Recording & Computers | 0 | 09-23-2001 03:20 |
| Settings | Whyte Ice | Cool Edit Pro / Adobe Audition Forum | 3 | 04-05-2001 17:50 |
| RNC settings | cjacek | The Rack | 6 | 01-05-2001 15:40 |
| eq settings | Tedstigers | Mixing / Mastering | 15 | 09-23-2000 06:35 |
