Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-01-2008
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
MOTU MTP II manual confguration
Hi All,
I have MOTU MidiTimePiece II that I have set up through the front panel controls.
I need help in figuring out how to take an input on one cable on some channel (say ch 8) and send it to another cable (oh say 7) and map channel 8 to channel 1.
My plan is to have Rosegarden output to cable 1 with more than one instrument (one instrument per channel) and have the MOTU take ch 7 and send it to a specific synth (that only knows about channel 1).
I'm still a noob with midi.....
Regards, Ethan
In Sunny Vancouver ..... (Washington)
Old 12-01-2008
lumstar lumstar is offline
Junior Member
lumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond reputelumstar has a reputation beyond repute
I have the manual, I'll take a look and give you instructions.
Old 12-01-2008
Junior Member
There are two steps to this process. First you need to map cable 1 input to cable 8 output. Then you need to map channel 7 to channel 1 on output cable 8. Here is how to do it:
Cable Mapping:
1) Use WINDOW knob to get to MIDI ROUTING menu
2) Use CURSOR knob to navigate to ROUTE BY CABLES sub-menu
3) Use SELECT knob to select the incoming cable (in this case cable 1)
4) Use VALUE knob to select the outgoing cable in (in this case cable 8)
Channel Re-mapping
1) Use the WINDOW knob to go to MIDI CHANNEL MAP menu
2) Use CURSOR knob to select OUT CHANNEL REMAP sub-menu
3) Select cable using SELECT knob to set the cable value (in this case 8)
4) Use VALUE knob to set source channel (in this case 7)
5) Switch to destination channel using CURSOR knob
6) Use VALUE knob to set destination channel (in this case 8)
Let me know how it works for you!
Old 12-08-2008
evm1024's Avatar
1K Silver Member
Thanks!
Thanks, that worked. I had a little confusion and had to play a bit but your instructions got me there.
Is your manual scanned? I'm not ablr to find one....
Thanks , Ethan
Old 12-12-2008
Junior Member
I have the original. I haven't seen it online anywhere either. Sorry.
Tascam 488 mkII manual or service manual? analog aaron TASCAM User Forum 2 12-09-2007 15:35
does anyone have the manual of the Motu 828 MK1? earworm Digital Recording & Computers 0 09-05-2007 03:11
MOTU 828 mkii Manual ChuckU Digital Recording & Computers 2 01-28-2007 19:00
Looking for a manual for Motu MTP AV roody MIDI Mania 3 07-20-2004 07:00
MIDI Express XT (MOTU). Anyone know where there's a manual? Krakit MIDI Mania 2 09-29-2003 20:44
