Cheap and Easy Battery Replacement
The recent post on the KX-88 problems reminded me...
Batteries Plus replaced the memory battery on my ESQ-1 for something like $11 or less- and that included labor! Just the battery at Radio Shaft was $11, and I figured let them do it- that way if something goes wrong, they replace my synth. Nothing went wrong, but the store personnel confirmed that if they had fried my synth, they would, indeed, have replaced it. Took about 30 minutes, actually less, I went to lunch and came back. They even tested everything to make sure it was done right. What service! |
It is much better way for exchanging your next batteries, not to mention, more elegant and safer for longevity of your board. Depending of what is available to your technician or your best store...holders range from generic PCB holders (mostly found on motherboards) to more precise and higher grade holders; some very unique where space is limited and restricted. Should be well soldered and checked properly. In your particular case with ESQ's battery, make sure you tightly secure with bat. holder. I mean completely firm and robust to withstand any movement and your occasional or frequent transports without any issues. After that you are completely relaxed ![]() I understand this is probably overkill for some users with moderate amount of gear. Specially with machines like these were battery autonomy can easily jump to next decade. But, I simply can't stand any board(s) without battery holder. No difference if we are talking economical of high-end range of equipment. This is something I do even before unpacking ![]() .
http://tinyurl.com/y85sqk http://tinyurl.com/y7runw http://tinyurl.com/yx3khf http://tinyurl.com/wj9ry ~ Sorry~ Last edited by Anthony; 11-30-2008 at 20:43.. Reason: link correction |
Didn't you understand? Battery ALREADY replaced, done and done. Not going back in to change it.
![]() Besides, I'm sure you will live too see another battery replacement. ... Last edited by Anthony; 12-01-2008 at 07:36.. Reason: don't sleep and drive |
PCB battery holder is OK for coin cell batteries and worth the time to do, but apparently the ESQ-1 battery is slightly larger. Image below is from this site http://www.pic101.com/ensoniq/battery.htm on changing the ESQ-1 battery. Yellow cylinder is the battery.
11 bucks to have a soldered in battery changed is real reasonable and if you only have to do it every ten years or so is well worth the cost. |
http://tinyurl.com/y85sqk http://tinyurl.com/y7runw http://tinyurl.com/yx3khf http://tinyurl.com/wj9ry ~ Sorry~ |
The size of the factory battery isn't really important. What matters is the voltage and capacity. That said, the capacity mainly gives you an idea of how many years it will last, so the critical bit is the voltage. If you can tell us what the factory battery capacity was, that would make it easier to specify a more exact replacement, but it isn't strictly necessary to do so.
This battery should be a good substitute: http://www.radioshack.com/product/in...ductId=2151273 and you can use this clip to hold it: http://search.digikey.com/scripts/Dk...?name=1029K-ND It even has a snap-on top to keep the battery from jumping out no matter what you do to the thing. You can get similar clips for pretty much any variety of battery. Note: depending on whether the pins happen to line up or not, you might end up running wires to the battery holder and fasten it to the inside of the case with tape or something. If you can provide an exact part for the factory battery (I've had no lucky finding that information), that would help a lot in picking a more exact substitute. ![]()
| Can it be this easy and cheap? | mikemorgan | Digital Recording & Computers | 18 | 01-22-2007 19:40 |
| battery powered preamp on the cheap | daav | Microphones | 11 | 06-08-2005 16:11 |
| Cheap Mac Replacement Strategy Needed | Todzilla | Keyboards and Sound Modules | 9 | 03-08-2005 15:12 |
| Tascam 688 Battery Replacement | PALM Studios | TASCAM User Forum | 0 | 09-09-2004 17:30 |
| Easy Mod for older 9v battery power only pedals | maestro_dmc | Guitars and Basses | 0 | 06-11-2003 13:48 |
