Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-21-2008
AMcB's Avatar
AMcB AMcB is offline
Why you gotta be so mean?
AMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond repute
Ddrum Triggers For MIDI
I would like to get some ddrum triggers, and I would like to use them for a program like ezdrummer. How would I convert the trigger which has a xlr output into the mide for the ezdrummer. My interface is a firepod, if that helps. I dont want to have to buy a drum module, is there like a single channel xlr to midi box or something? Thanks!
Old 11-22-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
You need a drum brain. (a convertor that takes the pulse and converts to midi)
http://www.zzounds.com/item--ALETRIGGERIO
I suppose that you could record the pulses as hit points, but I have never done it that way
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-22-2008
AMcB's Avatar
How would I do that? Would that go into midi? Thank!
Old 11-24-2008
no. You record is as an audio track. Depending on which software you use, it will be different. In Cubase, they call it "Hit points" and it effectively puts markers where the hit is. I personally dont use so I cannot elaborate more about it. I just midi in my drums via pads. If you are going to spend money on triggers, you may as well get a brain
Old 11-24-2008
AMcB's Avatar
Thanks, I think I figured it out with something like ktrigger or something, I'm at work I can't remember exactly what it is. The reason I do t want a drum mod because I am only using it for the snare, and I don't need all the other stuff it comes with.
Old 11-24-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Yup, just record the trigger as if it was a mic and use a plugin that converts the hits to midi. Drumagog does that very nicely.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-24-2008
AMcB's Avatar
Drumagog converts it into midi? Like I could put it in drumagog then into ezdrummer?
Old 11-24-2008
Farview's Avatar
Drumagog will convert it to midi, trigger from midi, trigger it's own samples, and a bunch of other stuff.
Jay Walsh
Old 11-25-2008
MrMcSick's Avatar
MrMcSick MrMcSick is offline
Newbie
MrMcSick is on a distinguished road
Buy an Alesis Trigger I/O. Its only $150 and you can plug up to 10 triggers into it, it then converts them to midi and you plug it into a usb port on your computer. It even comes with BFD lite so all you do is hook up the triggers, plug in the usb and open the DAW or BFD stand alone app. DONE.
Old 12-18-2008
tangerine's Avatar
tangerine tangerine is offline
grumpy bastard
tangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond repute
Akai used to do an MT35 midi trigger, you can make the triggers yourself.
I give espskully the splats
DDrum or Roland Triggers ChadAustin Drums and Percussion 4 08-24-2008 11:55
DDrum Triggers - Use or Don't Use? lindberg711 Other Equipment and Reviews 2 01-03-2006 12:54
WTB: Ddrum XLR triggers or equivalent tubedude Free Ads for Music / Recording Equipment 0 12-29-2005 13:13
WTB: ddrum pro triggers girlthatdrums Free Ads for Music / Recording Equipment 2 11-15-2005 15:24
Roland Triggers better than ddrum red dot triggers? brnjn Drums and Percussion 0 03-16-2005 06:36
