Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-19-2008
pianoman1976's Avatar
pianoman1976 pianoman1976 is offline
Clandestine Physicist
pianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond reputepianoman1976 has a reputation beyond repute
Question Help with Computer/MIDI connections
Hello,
I need some advice as to how to properly connect my MIDI cables. I use a Roland piano controller and a rack mounted Roland XV-3080 sound module. I have an iMac with an M-Audio Ozonic firewire interface. I've had no problem hooking everything up correctly in order to send MIDI from my piano to both my XV-3080 and my computer.
I've installed a Roland XV-3080 software editor and librarian program in my iMac. I assume for this program to access my XV module, I need to send MIDI OUT from my computer (through my Ozonic interface) to the XV module, correct? I'm already using the MIDI IN on my XV module (connected to MIDI OUT from my piano) so I'm confused as to how to get another MIDI signal into the XV. I'm sure it involves MIDI THRU yet I'm new to this and could use a little 411.
Thanks.
Old 11-20-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
get a dedicated interface with more ports. With software editors, the case is almost always that they need a "full loop" meaning that it needs to communicate to the device and have parameters sent from the device, this takes up both ports. The work around would be to put a merge box in line with the midi outs of the XV and you controller going into the midi in of your Ozonic
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 11-20-2008
I have a Yamaha YME8 MIDI expander:
http://www.tokaimusic.com/shop/t/tok...29134814_b.jpg
Will this work? If so, I would appreciate being told exactly how to hook it up.
Thanks.
Old 11-20-2008
that should work. Connect the midi outs from the controller and XV to the midi in 1 and 2 and the midi thru to your maudio. Make sure the switches are set correctly so both ins are routed to the thru
Old 11-21-2008
I feel like a monkey in one of those logic experiments. I'm still stuck. Take a close look at the picture of my YME8. It seems as if both IN's cannot be routed together to a THRU. Selecting one of the IN's to either the top or bottom bank of THRU's disables the other IN from going to that same bank.
I may be mildy retarderd, so please verify this.
Thanks
Old 11-21-2008
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
With what you have I dont think that will work, it wont let you merge two midi inputs to one thru. look at one of these.
http://www.zzounds.com/item--MSLMERGER
Carter
MCF Productions
Old 11-21-2008
Thanks
If that is the case, then no it wont work.. Sorry
USB Hub with no midi connections? How do I midi Sync? PaulKarate MIDI Mania 3 11-16-2005 02:56
MIDI connections rustyfingers MIDI Mania 4 01-14-2004 20:54
MIDI Connections jerberson12 MIDI Mania 3 07-24-2003 21:50
Computer/Reference Amp Connections blacksummerrain Cakewalk / Sonar Forum 2 01-31-2003 19:22
MIDI connections? guitar ed MIDI Mania 7 04-09-2002 22:39
