Open-frame? Closed-frame?
Gold contacts? Does it matter? This'd be for 8-pin dual opamp installations... Any recommendations from the Digikey or Mouser catalogs? Thanks. ![]() |
From what I heard these http://www.gme.cz/_dokumentace/dokum....824-001.1.jpg
should be better than these http://www.gme.cz/_dokumentace/dokum....823-010.1.jpg
dont bother with the gold... two dissimilar metals put together has electrolysis problems...
actually i never use sockets unless it's something i know i'm going to experiment with.. the reason being that they can cause some problems due to interelement capacitence... ymmv..
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
For testing...
Thanks for the caution, demented, and the recommendation kubeek...
Yeah, this would just be for a couple spare M-520 channel cards for testing different opamps. So, any other specific recommendations? |
I've used THESE in the past, and they work just fine. Then again, I don't have any real experience with any other type. Light "Cowards can never be moral." M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children." -Aqeela Sherrills http://www.theforgivenessproject.com/ |
Just be sure you roll the pins properly. There was a tale that the original Apple II had a high failure rate caused by chips popping out of sockets because the pins were still bent too far outward and their natural springiness pushed the chips out of their sockets. The test? Pick it up and drop it a few inches to reseat the chips. If that fixed the problem, crack the case and push on all of them manually.
I just use the super cheap ones that are like 5c a piece and I have never had a problem with chips poping out, they actually hold the chip extremely firmly so I have to use a screwdriver to get the chips out....One thing I do do is I tin the legs of the opamp which seems to protect them from oxidation so the contact stays good but this is just a safety measure on my part.....
Cheers
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
Thanks for all the replies everybody!
So Am I right that regardless of what sockets I get, I want to order the chips with pins and not solder legs? |
No, you would want DIP Chips which have Pins , the ones with solder pads are really small and won"t fit in a Dip socket and they are very hard to work with because of there size....
Right...okay...I've got the difference between the surface-mount chips and the through-hole chips, but there are, for instance, through-hole DIP OPA2134 chips at Mouser that have either pins, or solder tails...If I'm mounting them in sockets I want the former right?
You have pins on a DIP-8 package or tabs on a SOIC (SMT). You want DIP-8, which is OPA2134PA. |
#12
Okay...thx msh et al. I think that's where I was getting confused, though I was looking at the 2134PA so even in my ignorance I was on the right track.
| Overloading plug sockets | chamelious | Other Equipment and Reviews | 1 | 09-12-2005 18:23 |
| Chassis mount DIN 5 MIDI sockets? | Krakit | MIDI Mania | 2 | 01-31-2005 09:11 |
| Power Sockets (In the UK) | chamelious | Other Equipment and Reviews | 1 | 06-06-2004 02:48 |
