Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 10-31-2008
wpaldridge wpaldridge is offline
Newbie
wpaldridge is on a distinguished road
Mod Allen & Heath for direct outs?
Hey, guys (are there gals on here?).
An Allen & Heath SR 424 (allen-heath.com/veterans/sr.htm) mixer has recently come into my possession. It has great pre's/EQ and I really wanted to use it in my computer set-up (16 channels), but the damn thing has no direct outs.
Is it possible to modify the board and put in my own direct outs? Is it as simple as finding where the signal goes from the individual channel to the main out?
I'm reasonably competent when it comes to electronics and soldering and such, but would it be worth my time?
Any tips/tricks from any of you experienced mod'ers? What's a good brand of jacks to use? What kind of wire for the internal connections?
Or should I just bite the bullet and get a new mixer?
Thanks!
What side of the tracks are you on?
Both sides because the world is round.
~Geggy Tah, "Sacred Cow"
Old 10-31-2008
theobvioustroll theobvioustroll is offline
Newbie
theobvioustroll is on a distinguished road
Well, if you really wanted to, you should be able to tap off of the fader, and have a post fader direct out.
Old 10-31-2008
Newbie
That's what I was intending. I just want some input as to whether it'd be more trouble than it's worth. Also, what materials (jacks, wires, etc.) I should be looking at.
Old 10-31-2008
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Check the manual or email A&H, because a lot of their boards have internal options that could make that mod quite easy. I'm not familiar with that board though.
Old 11-01-2008
Newbie
It's from the Mid 80's - it's a good board, but it is really kind of barebones; a friend had one... I think that model sold for around $1,500 in say... 1985 or 1986.... I remember thinking that was a small fortune for a mixingboard considering we paid $2,500 for a huge (used) 24-channel Peavey soundsystem with 6 CS800 and 2 CS400 amplifiers. LOL
Old 11-01-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
you want the outputs to be pre-fader... either pre/post eq... alotta ahb boards have internal jumpers so you can config the sub groups or sends pre/post... that's where i'ld be looking to tap in... what kind of convertor are you useing??? does it want balanced outputs feeding it???
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 11-02-2008
Newbie
Well, if you wanted them prefader, you could just install a patch point using a 1/4" TRS Jack (IIRC it's a closed circuit jack - you'd have to look at the jack - the one you'd need has an extra piece on it that makes contact when there is no jack present in the return section of it - so that teh signal will continue through the channel like a normalled patchbay.) Your option would be to either go pre or post EQ, or I guess if you really wantedto get into it, you could make it switched so you could flip back and forth between the two.
Tim
Old 11-03-2008
what the troll is not taking into account is the points he's suggesting you use may not be able to drive the output... muchless the output and whatever it is already driving... do your homework... unless you think screwing up a good old board is fun.... ymmv..
Old 11-04-2008
MrBluesMan MrBluesMan is offline
Newbie
MrBluesMan is on a distinguished road
I would agree its not worth screwing it up just to obtain a quick fix for your direct out problem. At the very least you can use the inserts as Direct outs just so you can utilise the pre-amps.
I would buy a new mixer personally.
Allen and Heath bunglebungle Mixing / Mastering 6 06-15-2004 06:58
Allen & Heath....or something else? sjaguar13 Other Equipment and Reviews 10 08-22-2003 12:40
Allen & Heath GL3 / GS3? valdemar The Rack 1 01-29-2002 22:21
allen & heath 16:2 seriousturtle Mixing / Mastering 0 06-06-2001 12:10
