Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 10-29-2008
Guitarer Guitarer is offline
Custom User Title
Guitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond repute
Wanna mod my 603s?
I got a pair of MXL 603S mics during the MF stupid deal of the day, and am intrigued by the cheap mod everyone was talking about. I don't currently have a soldering iron, nor the time...nor the trust (in myself) to open them up and mess with em. Twas wondering if I could ship the pair to one of you guys and have you do it for me. I know the place everyone was buying the parts from made you buy extra.
Thanks,
Holden
Old 10-29-2008
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
what is this mod and how do i do it? I have a pair that I'd like to improve, and if I could do those I could do yours.
Old 10-29-2008
Custom User Title
Here's the mod Antichef posted in the 603 Deal thread. Really like the results he got.
Originally Posted by antichef View Post
OK, back home, and I just did the mods. DrBill has, with his drum samples post, set a new standard in shootouts that I will never attain. With that advance apology out of the way (and the disclaimer that I have no skills and don't know what I'm doing), I can say that I did take pictures and record short samples. I forgot to use the low tech match testing technique prior the mod, but I'll do it with the modded mics and post again.
OK first, here are the mics stock, with the victim capacitors indicated (my mics do not have the trim pot that Marik mentioned, unfortunately, but - not obvious in the picture, they do have 1G ohm resistors (those maroon plate-like looking things) unlike my 991):
and here's a stereo (using both mics at once) sample of a little drum thing and a porcelain bell that I've got. Unlike drBill, I'm going for information underload
http://recursor.net/mxl603/MXL-603-stock.wav
next, here they are with the input capacitors swapped:
the replacement 1000pf poly-something capacitors are a little bigger physically than the stock ceramic (also 1000pf) ones, but they fit fine. Here's the corresponding sample:
http://recursor.net/mxl603/MXL-603-inputcap.wav
sounds better to me -- one thing that may not be apparent in the sample is, despite my neaderthalic soldering skills and sub $10 soldering iron, the mics are less noisy.
next, I decided to follow Marik's advice and go with 1uf capacitors to replace the .22 ones -- I quickly realized that I had a form factor problem -- my first choice of replacements just didn't fit at all (actually, my first choice are these WIMA ones that would probably fit, but I only had one of them left !!! argh!!!). I managed to get these yellow ones in place by leaving long leads and tucking away -- being careful to avoid a short, of course:
here's the mic again, with the capacitors tucked away:
and here's the sample:
http://recursor.net/mxl603/MXL-603-.22to1uf.wav
[I did my best with mic placement across the samples, btw, using a stereo bar on a stand for the mics, and holding the drum and bell in as close to the same position as I could.]
even better, I think - more bass. And again, quieter. Thanks again, Marik! Next, I'll have to figure out how to remachine the capsules with my teeth
edit: matching is OK, but not fantastic, with the mismatch pronounced at lower frequencies - my guess is about 5-7 db off below 200hz. I'm speculating, but I imagine that by improving the bass response, I worsened the matching a little, since the poor bass response on the stock mics was masking the mismatch. I had the same effect with some MC-012s that I modified.
Old 10-29-2008
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
Sure
I'll do the mod. Got the parts? I have some wima's and some 820 pf polystyrene caps floating around. Need 1000 pf, I'll have to order them. Just the 3 parts per mic is easy.
Just pop them in the mail. (seriously)
-Ethan
In Sunny Vancouver ..... (Washington)
Old 10-30-2008
Custom User Title
I don't have the parts. I was hoping someone with some leftovers from their mod would be willing to part with a couple caps.
Old 11-02-2008
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
I can do it - I've got the parts. I may need as much as a few weeks (actually not much time, but I'll have to have an hour without distractions and without the two year old grabbing for the soldering iron , and the few weeks is a worst case scenario kind of expectations-setting time frame ).
Old 11-02-2008
Custom User Title
Awesome! I appreciate it man PM me your address. I'm in no rush.
If you want, I can paypal you a few bucks for your time/shipping back to me too.
-Holden
MXL 603s + Pickup OR 2 MXL 603s' Beantowna Microphones 21 08-21-2006 11:42
using MXL 603 and 603s Harlequin Man Microphones 0 11-25-2005 08:14
603s vs. 603s mogami distortedrumble Microphones 2 01-11-2005 09:51
just got me some 603s! ZEKE SAYER Microphones 4 09-10-2002 21:10
MXL 603s? micros Microphones 6 01-29-2002 22:42
