Hello everyone, i have an MCI JH-528 C mixing console, i have the no line input transformers version on the frame, instead it has the diff amps in there. I recently bought 28 MCI JH-600 input trafos taken from a dead console. What i want to do is to install this in my console, before the diff amps, it wont be an easy job, because i think i may modify a little bit the diff amp circuitry, specifically resistor values.
So my first question is this: Does any one knows the ratio and impedance ratio of the JH-600 input trafos????, i think the JH-500 uses 1:4 input trafos, but i dont know if the JH-600 are the same, i also dont know the impedance ratio of the trafos of the JH-600, here are some pics of the JH-600 trafos, 2 blue wires on the primary side, and 2 red wires on the secondaries, green i think is ground: ![]() ![]() Now here's a pic of the line input trafos used on the JH-500 console: ![]() ![]() My second question is this, does any one knows the mods i should perform to the diff amp on my JH-500 C if i want to wire the trafos in it?, i mean for instance on JH-500 D series, the diff amp is found inside the I/O module, but here my diff amps are where the trafos should be... Here's the JH-500 diff amp schematic: ![]() Thanks For your help |
Ok, no one answered but ok, if anyone wants to know, i find out they were actually output trafos 1:1 600:600 ohm
party time!!!!!!!!!!!!! |
The guy to ask about all things MCI is Steve Sadler at Blevins Audio in Nashville.
-Fishmed |
| To frame or not to frame (OC 703)... | Myriad_Rocker | Studio Building & Display | 22 | 06-20-2006 07:31 |
| Frame Construction | tapestry | Studio Building & Display | 4 | 06-17-2005 05:52 |
| Revised Desk based on PK1's desk | dcwave | Studio Building & Display | 19 | 06-06-2005 02:07 |
| To frame or not to frame? Bass traps | joshj | Studio Building & Display | 14 | 12-05-2004 18:06 |
