Old 10-28-2008
Horkin My Lunch's Avatar
Horkin My Lunch Horkin My Lunch is offline
Newbie
Horkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond reputeHorkin My Lunch has a reputation beyond repute
When I say "drum sounds", I mean the overall sound of the drums you're trying to achieve with compressors or EQs before whatever you're tracking to (tape, pro tools, etc.). I don't EQ going in, but I'm having difficulty being time efficient when setting up sounds. So, Home Recording Forums, what methods do you use to set up compression (or even EQ tips if you're so inclined) in the analog arena?
edit: i spelled efficient wong in the title. i am a dumb.
Old 10-28-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I'm not even sure of what you're asking...
Short of literally "changing" drum sounds (as you might be inclined to do for metal or what not), the drums should sound pretty much the way you want them to before you even put a mic on them.
Nothing is going to save an out-of-tune kit.
Nothing is going to save a kit with bad heads.
Nothing is going to save a kit with the wrong sound.
Drummers that don't hit "like a girl" (no offense to some of the great women drummers in the world) need little in the way of corrective dynamics.
Setting up compression? You compress things that have a dynamic range too wide for the rest of the mix. You compress them until they have a dynamic range that fits more in line with the mix. There's no starting point, there's no short-cut.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 10-28-2008
Newbie
I guess I forgot this part: do you usually set compression while the drummer plays the whole kit or do you work drum by drum? What is more time efficient? I'm not talking about "compression settings." I also understand that you should set up the drums sounds the way you want through micing, but I usually compress the kick, snare, and toms just a little bit while going in.
Old 10-28-2008
I tend to work one by one while listening to the entire mix - or at the very least, a drum mix.
This is also why I record 5-10 minute drum checks with particular patterns and rolls...
setting up field studio gear barakazen Microphones 2 07-24-2006 09:17
setting up my gear HELP milb9819 Fostex Forum 2 12-06-2005 14:08
Setting a timeline for buying gear. Who's on track? Chris Fallen The Rack 9 09-24-2003 19:40
setting up recording gear syonce Newbies 1 09-08-2003 06:27
patching my components in an effecient way fabfour1257 The Rack 2 01-22-2003 03:10
