Old 10-27-2008
KyleAtGalaxy's Avatar
KyleAtGalaxy KyleAtGalaxy is offline
Dedicated newb
KyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond reputeKyleAtGalaxy has a reputation beyond repute
Mic placement when tracking drums
I'm going to do some drum tracking tomorrow and I wanted to try to get some opinions on the best way to set up my mics. I'll be using a 57, a sennheiser e609, and a pair oh Behringer B5 condenser mics. I also have an AKG Perception 200 but I don't think I'll be of much use unless possibly as a kick mic.
I plan to put the 57 in the kick, the e609 on the snare, and use the b5s as over heads.
Here is my question: How should I place the B5 mics? In xy stereo? Or have one pointed over the left of the kit and have one pointed over the right? Also, I planned on using the cardioid capsules but maybe I should consider switching them to omni.
I realize the best answer is to experiment and try out each scenario and I'll do that. I'm just looking for a shove in the right direction. As of now I'm leaning toward having each condenser mic on opposite sides of the kit with the cardioid capsules on.
Thanks for taking the time
Old 10-27-2008
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
The "Recorderman" method is a pretty foolproof overhead technique that will work for multiple styles and sounds great, imo. Described well in this video:
http://www.youtube.com/watch?v=IiFOD1EeKhQ
"That was so terrible, I think you gave me cancer!"
My tunage
Old 10-27-2008
Dedicated newb
Thanks alot for the link. I've actually been reading some threads about it. Sounds like a great technique
Old 10-27-2008
tojo tojo is offline
Force of Nature
tojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond reputetojo has a reputation beyond repute
let me know how it goes if you use recorderman technique
Old 10-27-2008
Russtopher Russtopher is offline
Senior Member
Russtopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond reputeRusstopher has a reputation beyond repute
Check the "great drum sound with 3 mics" thread in the drums forum here, excellent excellent advice there. You can also try the "Glyn Johns" micing technique, which I find gives a bit more tom response than Recorderman.
How it sounds when a drummer attempts to record everything himself in a wrock band - Creevey Crisis
Old 10-27-2008
Dedicated newb
Yeah I will for sure experiment with different placements. For the RECORDERMAN technique would you say I should try omni or cardioid mics?
Old 10-28-2008
Senior Member
The "better" option may depend on how close you're putting the mics to the kit, how your room sounds, etc. Omni are going to pick up more of the room sound, so if you're in a small tight space that has a lot of early reflections, cardoid might sound better. IIRC those Behri mics have swappable capsules, correct? If so, get your mics set based on the setup you want, and record samples of both and give 'em a listen
Old 10-28-2008
DM1 DM1 is offline
Senior Member
DM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond repute
Agree with Russtopher. Unless you have some kind of treatment above the mics, or high ceilings, the omnis can pick up more ugly reflections.
Also, if you can record all 5 mics at the same time, consider using the AKG as a room mic. Get it as far from the kit as you can, and maybe slam it with a compressor too.
Old 10-28-2008
Dedicated newb
Awesome guys, Thanks. Hopefully I'll be able to post some samples soon
Old 10-29-2008
Dedicated newb
Here's a few minutes of drums from using the recorderman technique. Two B5 overheads, a 57 on the kick and a e609 on the snare
http://www.soundclick.com/reasonstowritehome
Thanks!
Old 10-29-2008
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
Thanks!
Sounds pretty good to me!
I'd perhaps carve a bit of mids out of the kick as well as the snare - and compress the snare to bring out a bit more attack perhaps.
Did you try adding a room mic?
good job
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
  #12
Old 10-29-2008
Dedicated newb
good job
Thank you! No, I didn't use a room mic. I'm using an Mbox2 pro to record with and I'm a little limited on inputs. If had more time a could've probably fit it into the over head sub mix. It'll give me something to try next time!
Mic placement for tracking bass Bulls Hit Recording Techniques 23 11-10-2006 09:31
Headphone amp rack/placement in tracking rooms SRR The Rack 1 03-07-2006 19:34
mic placement for double tracking Big Kenny Microphones 38 10-30-2004 10:45
mic placement for drums SteveDW Drums and Percussion 8 03-22-2001 19:15
mic placement for drums SteveDW Microphones 2 03-11-2001 07:20
