Old 10-21-2008
stupidfatnugly stupidfatnugly is offline
Dedicated Member
stupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond reputestupidfatnugly has a reputation beyond repute
In what order
do you put EQ, compressor and Gate on your inserts?
Old 10-21-2008
ghetto3jon ghetto3jon is offline
Dedicated Member
ghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond reputeghetto3jon has a reputation beyond repute
sure, if i think it needs gating, equalization, and compression. typically, my order is Gate -> EQ -> Compressor.
(antichef's DMP3 giveaway ends tomorrow...vote for me or someone else: http://homerecording.com/bbs/showthread.php?t=271855)
Old 10-21-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Corrective EQ first almost always. You don't want (whatever you might be correcting) to trigger a gate or to affect the gain going to a compressor (generally).
After that, it gets weird - If you're using the compressor "as a compressor" you'd probably want it right after the EQ and gate it last. Otherwise, the gate will cut off all the gain to the compressor prematurely.
People still use gates?
Anyway, it can depend on what you're gating to some extent.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 10-21-2008
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
FixEQ --> Comp --> PolishingEQ --> (Reverb)
FixEQ to remove the honkers that compression would otherwise bring out, then compress, then gentle EQ (if necessary) to polish what's left. Then, if desired, reverb last.
I almost never use gates, personally. Don't see much need for them in today's world of digital editing.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 10-21-2008
Dedicated Member
I'm just trying to quiet amp noise with it.
am I worrying too much about amp noise?
I voted for you ghettojon
Old 10-21-2008
The Black Circl The Black Circl is offline
Junior Member
The Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond reputeThe Black Circl has a reputation beyond repute
you sould look for an alternative method of reducing amp noise other then applying effects.
Effects are for enhancement - not for masking or solving problems
Old 10-22-2008
fuzzrhythm fuzzrhythm is offline
Senior Member
fuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond repute
To get rid of amp noise you can automate your guitar tracks to turn down or mute the volume when you're not playing. It's very tedious, but it helps you get in the habit of automating which IMO sounds better than gating.
Gates can come in handy for distorted guitar on industrial and dance tracks, where it's used more for flavor.
Old 10-22-2008
dang donkey's Avatar
dang donkey dang donkey is offline
Newbie
dang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond reputedang donkey has a reputation beyond repute
How bad is the amp noise?
Is it the same through different instruments?'
Placement maybe an issue.
The instrument itself maybe suspect as well.
I guess we need more input.
DD
Old 10-22-2008
EQ the signal first - Does it make the noise better or worse?
Better - Gate post EQ.
Worse - Gate pre EQ.
Old 10-22-2008
Dedicated Member
I just delete all that stuff in between
that's fine right?
Old 10-22-2008
Dedicated Member
DD
my guitar and bass are cheap and old
I need to get new ones
it is the same through the two different basses I have tried (my cheap one and one my friend built himself) so I don't know
  #12
Old 10-23-2008
jaybriggs84 jaybriggs84 is offline
Dedicated Member
jaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond repute
Like they have said before, do your gating and corrective EQing first. As for EQ and compression, it depends on the use. Someone asked Dave Pensado about the order of EQ and Compression, here was his response.
1st ask if you wanna EQ the compressor, or compress the EQ. Think about this for a minute. Say you have a fat lo-endy kik. You don't want all that 60-80 triggering the compressor. So compress it first to bring out the knock, and EQ the lo end back in. On a guitar you might want to EQ it to get all the strings to sound, or to bring out a certain frequency, then compress it a tad to keep it in a certain dynamic range, or to bring out the attack. Remember, if you put the EQ 1st, then you have to reset the compressor everytime you make an EQ change. But always remember, there are no rules, just what sounds good to you. Experiment.
  #13
Old 10-23-2008
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
1. Compressor
2. EQ
3. Gate
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
In what order... djdarwin DJ & Hip Hop Production 11 07-25-2006 09:39
The ORDER. Thanks...now how about the order while mixing? DinoD The Rack 1 07-25-2002 17:12
