Old 10-19-2008
MattNZ MattNZ is offline
Junior Member
MattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond repute
Mic Pres
As a fairly new recordist, I’m just getting my head around mic pres and their function. Now as far as I understand it, these preamps are there to amplify the signal from a microphone to an acceptable level and provide phantom power where required.
Like a lot of users on this site, I have an Edirol UA-25 USB interface.
This is a cracking little box with a couple of built in mic pres. However, if I wanted to try out some other new mic preamps, am I able to switch off the pres within the Edirol? If not, what are the repercussions of two lots of preamps in the signal chain?
Please, no RTFM replies – I have done. The word preamp is mentioned only once in the UA-25 manual.
Old 10-21-2008
RRuskin RRuskin is offline
Rick Ruskin
RRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond reputeRRuskin has a reputation beyond repute
Does this Edirol have any line ins? If so, use them to bypass the preamp stage.
Rick Ruskin
Lion Dog Music - Seattle WA
http://liondogmusic.com
Old 10-21-2008
KineticSound's Avatar
KineticSound KineticSound is offline
The VOICE
KineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond reputeKineticSound has a reputation beyond repute
Looks like the inputs on the UA-25 are combo-jacks. I'm not 100% certain, but I bet the 1/4" plugs on those get fed through the same preamp circuit as the XLR signal. You do have a set of digital inputs, however they're of the optical variety and I'm not aware of many decent, entry-level preamps with optical cards on them. Most of what you see is Coax (or AES/EBU on higher end units).
To answer your original question, running one preamp into another is certainly not ideal. Is there a particular reason you're not happy with the Edirol's preamps? What sort of microphone are you running into it?
8 Channel Rackmount Pres as compared to Soundcraft M12 Board Pres Chris F The Rack 11 01-28-2005 21:12
Soundcraft Spirit Notepad pres VS. DMP3 pres Gidge The Rack 2 10-01-2004 08:34
soundcarft m12 pres/ vs digi 002 pres vs behringer ub pres lbcstudios The Rack 5 07-16-2004 11:56
Soundcraft Spirit M12 Pres vs. DMP-3 or other budget clean Pres Chris F The Rack 2 05-30-2004 19:59
Digi 001 pres versys Yamaha MX12/6 pres cordura21 Recording Techniques 3 07-17-2003 06:08
