Old 10-19-2008
minds device minds device is offline
Newbie
minds device is on a distinguished road
Recording Bass (signal chain)
Here is the gear
Bass Guitar
DBX 166XL Compressor
Tech 21 Sans Amp DI Box
Presonus Firepod Preamp/Interface
What is the proper order?
Old 10-19-2008
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
You don't need a DI with the Firepod, the first two preamps should have instrument level inputs (I know the Firestudio does).
Do you really want to use the compressor, or do you want to wait until after you have recorded to put it in post. If its part of your sound, then Bass->Compressor->Firepod. If not, then remove the compressor.
Old 10-19-2008
MattNZ MattNZ is offline
Junior Member
MattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond reputeMattNZ has a reputation beyond repute
Depends on sound, but I'd use the SansAmp over the pres on the Presonus any day!
Old 10-19-2008
Ironklad Audio Ironklad Audio is offline
1K Silver Member
Ironklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond repute
he doesn't NEED the sansamp in there, but it's much more than just a DI...
i would try bass-->sansamp-->comp-->firepod first...then maybe give it a whirl without the comp, and see which you like more
Old 10-19-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
The comp shouldn't be in the chain really - not recording into a comp. The sans amp will deal with some of the compression issues anyway.
I'd try bass -> Firepod 1st and see how you feel about the sound you get.
If you don't like the results then pop the sans in between & dial up the tone that's closest to what you're after.
Cheers
rayC
soundclick, unearthed, mspace & utub
help with signal chain Signal 9 Studio Newbies 7 02-13-2004 00:57
How Is This Signal Chain? MusicMan91 Newbies 13 12-14-2003 19:36
Recording signal chain Madmuzak Recording Techniques 2 03-22-2003 07:21
check this bass recording chain, got some problems cordura21 Recording Techniques 0 10-04-2002 06:54
Signal Chain, -what goes where? mcmd Recording Techniques 3 04-07-2002 22:46
