Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 05-03-2001
Uladine's Avatar
Uladine Uladine is offline
Dedicated Member
Uladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond reputeUladine has a reputation beyond repute
With the vs8f2 effects card for the vs 1880, can you add effects to a track after its already been recorded? Or do you have to add it as its being recorded? Can you add different effects to different tracks at the same time?
Old 05-04-2001
Roel's Avatar
Roel Roel is offline
That SMART guy.
Roel is on a distinguished road
Read the manual...
You can use the eff. in a different way. Normally you have a eff send for each channel, the effects return is handled as a normal input.
You can also use the effects as an insert. This means, your it is inserted in the signal flow, and all of the signal of your track (only for playback, or recording to another track) or input (for recording, or when using it as a mixer) go through the eff processor.
It's an allround eff. processor in the box. Very usefull... You can patch it any way you'd want. (Can't think of another way... As with a normal mixer, you use it as inserts or on aux...)
So, to answer your questions, you can add effects while recording, or after. And you can add eff to differen tracks at the same time. Also, one eff board has 2 processors on it. (2nd one is limited, some algorithms are only on 1st.) So, with 2 boards, you have 4 stereo eff processors in it...
