get rid of amp noise/hum
anybody know any secrets to minimizing the amount of amp noise that gets recorded?
If you like running your amp hot with the gain cranked up, there's not alot that you can do - you're raising the amps noise floor. As for guitars, Humbuckers don't produce as much extraneous noise as coils (nature of the beats and all that). Some pickup configurations are quieter than others; single coils wound out of phase for instance (positions 2 and 4 on a strat, traditionally). Also, whether or not the control cavity is shielded can play a part. Finally, other electronic items in the room can contribute to hum...computer monitors, certain types of lighting etc.
the place to start is have the amp serviced... there's all kinds things that can add bits of noise that can add up to too much... perhaps a noise gate???
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Gate it. this is assuming that you only hear the hum when the guitar is not playing.
If the noise goes up with the volume of the amp there's not much you can do besides gating and checking your equipment.
If the noise doesn't raise with the volume, turn up the amp to maximize the volume difference between the played guitar and the hum/noise. Cords can sometimes make a big difference. You can always try a ground lift as well. F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one" James Madison: the father of the Constitution |
Noise Gate? do I have a plug-in of this in protools? I think so but I don't know how to use it.
what's a ground lift? the amp is 3 weeks old so I don't think it needs servicing. my amp has a direct out and I'm just using that to record (no miking) why do I get noise when I go direct? |
A ground lift is one of those adapters that you use to plug a grounded 110V plug into a non-grounded wall socket. You just don't screw down the tab to the outlet cover. Quote:
Some amps are just noisier than others. The quality of the amp can make a huge difference. The noise level and whether or not it goes up and down with the overall volume are things you should look at when purchasing an amp. I'm not saying it is for sure the amp. You need to track it down by unplugging everything from the amp and seeing if the noise goes away or gets significantly better. You could have a bad cord, a bad ground in your guitar, a noise source in your room etc. Good Luck. F.S.
I would only use this if my receptacle didn't have a ground then, right?
If the noise is a low hum, it's probably a ground loop. Get a 3 prong to 2 prong adapter and see if that helps. They are normally less than $1. If the noise is more of a SSSHHHHH sort of sound, you are just stuck with it and need to try the gate.
OK I'll try that
would I have less of this noise if I got one of those really nice DI boxes I've heard of sansamp and countryman would those do the trick? |
The sansamp is a DI AND amp simulator, so you wouldn't need your amp. The countryman would work, but you could get away with a simple passive DI. Assuming you have line inputs on your interface, you really don't need a DI to come out of your line out. The only thing a DI would do is isolate the ground.
#12
dude you seem new to this. so DO NOT mess with mains wiring.. in the uk equipment without an earth is DEADLY.. with an earth it wont kill you (if your healthy) but will give you one hell of a suprise !!!
if your playing a guitar and get a shock you instantly grip tighter,you wont be able to let go... so your litrely toast !!! try using a notch filter in your software (there should be presets for 50 and 60 cycle hums) with a gate.... |
#13
For years we did not even have grounded circuits in homes and there are still plenty that don't. I have yet to be electricuted. F.S.
#14
It is grounded through the computer. (that's the problem) The only way for him to get electrocuted is if he becomes a better path to ground than the cable between his amp and the interface. If that was possible, he wouldn't have a ground loop.
#15
my amp has a ground lift switch on it, I just noticed so it probably sounds as good as it's gonna get.
do you get noise with a sansamp, then? "The sansamp is a DI AND amp simulator, so you wouldn't need your amp. The countryman would work, but you could get away with a simple passive DI. Assuming you have line inputs on your interface, you really don't need a DI to come out of your line out. The only thing a DI would do is isolate the ground." I'm lost as to what this means. I HAVE THE MBOX2 FOR AN INTERFACE which has line inputs, correct? don't all interfaces have those? |
#16
Cut down on the frecuencys in the recorded track put the low and hi at a certan frequency and slowly work your way down till its more quiet, it can also give the guitar a tighter sound
#17
There are two uses for a direct box.
1. Isolation. It electrically isolated the input from the output of the DI, so you don't get ground loops ans stuff like that. 2. impedance matching. Taking high impedance line signal and changes it to a low imedance mic signal All I'm saying is that you should just be able to plug the line out into the line in without a DI. However, you seem to have a ground loop problem so you might need to get one to isolate. You would plug the DI into the mic input of the m-box.
#18
if you're trying to get rid of buzz on a track you've already recorded, and it's consistent buzz, you could try the "phase reversal" trick. copy just buzz to a separate track, then reverse the phase. never had to try this, but some phase cancelation should occur...therefore, knocking down the apparent volume of the buzz.
#19
I've been doing some reading and it seems like there is some kind of noise reduction unit. hard ware or software that I can buy
somebody said something about it on another post what is it? |
#20
Do you hear the hum through the amps speaker when it is plugged into the interface, when you aren't plugged into the interface, or both?
#21
both
it's probably normal I just don't like it |
#22
what setting do you use on your gate for guitar and bass amps.
I'm trying to figure out how to use this plug-in my book says ratio all the way up and range at -80db I have to put the threshold at -50 in order for it to sound alright anyother suggestions? |
#23
Do you get the hum without your guitar plugged in?
#24
noise reduction plugins are a wonder for this.
even reafir is pretty decent @ it. |
#25
yeah it's the amp and it's probably normal but if I could minimize it even by the smallest amount I would be happier |
| Noise Gate Suggestions ? noise problems? Are noise gates Needed? | ljgmsun | The Rack | 8 | 02-21-2004 09:02 |
| computer noise/noise gate latency | saturdaysaint | Cubase User Forum | 1 | 08-09-2002 11:22 |
| white noise? noise generators?(analog synths) | electronicdreaming | Keyboards and Sound Modules | 7 | 02-15-2002 13:29 |
| noise noise noise....how I hate thou. | pudgystern | Mixing / Mastering | 7 | 03-29-2001 21:54 |
| Excess Noise...AHHHH!!! I hate Noise!! | clown7 | Other Equipment and Reviews | 4 | 06-15-2000 09:50 |
