Any tips on layering guitars??
I'm doing guitars on a 10 song album and want to get seperate guitar sounds for each song. We found a good setup and recorded all the parts changing the amp sounds and doubled and tripled up certain parts to thinken it up. but now i'm thinking of bringing the amp in a more dead room and doing even more layering.. how do you guys go about this?
Do it - if you don't like the results don't use them.
I think the easiest way to get a fuller sound is to switch guitas, pickups, amps and effects. Experiment with panning (don't just go with hard left/right), compression and reverb.
Agreed. Doing multiple takes of the same tone starts to muddy things up.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
Different guitars through different amps, EQed just enough to give each it's own space. Just changing the amp settings isn't enough to give you that full sound that layering several guitars will.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover |
and check all the guitars in mono to ensure that each one adds something to the frequency spectrum.
Going for complimentary tones is also generally a good idea. some of the heaviest guitar tones I've ever heard have come from two tones that sound like crap on their own, but fit together perfectly.
I won't try to give you specific EQ settings, because so much of that depends on your gear. Rather, the tip I'd give would be to evaluate every layer in the context of the mix, not on its' own. If you have four layers of sounds that rule when solo'd, odds are it'll turn to mud. Also, especially for heavy guitars, if you're doing a ton of tracks you might want to use less gain that you'd expect. |
So i have yet another question about guitar layering:
i want to record a song that has between 50-100 simultaneous and (mostly) identical guitar tracks. relatively clean tone, slow droning stuff. i know i should be switching guitars/amps/mics/preamps as much as possible, but is there any other trick to doing this properly? i did a test run with about 20 tracks, but i used the same guitar/amp setup the whole time, so the end result had a crazy bad eq sound to it and would not mix well with the rest of the song. any tips? thanks |
![]() dayum! |
#12
#13
#14
You said you had problems with 20 layers. 100 is only going to multiply the problem by 5 when you have 100 things all competing for the same frequency space.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos. Oh, and you know the thing about chaos? It's fair..." |
#15
i'm not doing that many layers just to get the sound to be "full", i'm doing it so that the sound goes beyond sounding like guitars. a special effect.
#16
If it's effects you want you can apply them to different instruments during different parts of the mix.My old band did this on a demo.We did an instrumental fade out to end the song and applied flange to the drums.It turned out to be a nice effect.It would have too overbearing if had been applied to the guitar since we would have lost the crunch and punch we wanted.On the drums it sat well in the mix & didn't take anything away from the other instruments.Just think of the whole picture. |
#17
because i like how it sounds. i just need a way to get it to mesh with the part before it, EQ wise. and so you know, this is a guitar-only drone type thing, i'm not putting 50 layers of guitar over a rock song with drums and bass and vocals etc.
i really don't know why you're all so offended by this idea. open your minds! |
#18
Sometimes you can open your mind to the point that your brains fall out.
#19
Where have you heard 50 layered guitar tracks before?
G. |
#20
screw the naysayers, go for it, i once interned at a studio where the lead engineer showed me a project with 48 guitar tracks, not saying they were identical, as this will only give you more perceived loudness but if you wanna try it try it, the problem you will face is that the tracks WILL fight each other in the mix and it WILL be a pain in the ass especialy if you havn't alot of experience with mixes of that complexity but this is recording and there really arent any hard and fast rules in my opinion if you wanna try it try it and if you like the result then bravo if not, screw it you didnt pay 50 bucks an hour to experiment in someone elses studio now did ya?
www.ninthhourrecording.com |
#21
just to bring in the 50+ layered guitars..........
i've seen some fall out boy and killers PT sessions where there were 40+ TRACKS of guitar playing at the same time. that said, these are normally summs, so 10 mics, 5 takes. |
#22
Translation: No need to ask questions on these forums, because only those answers that you find agreeable are the correct ones. What you need are a bunch of yes-men, not people who actually know the subject.
G. |
#23
Glenn Branca
and i'm asking questions on this forum to see if anyone has any helpful advice, not "that's ridiculous, don't do it". |
#24
This has officially become the thread from hell. It has 666 views at the moment!!! Hells yeah!!!
#25
I think that if you actually listened to what people are telling you, you would realize that they are giving you advice - you're just not hearing it.......
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
| Tips On Tracking Guitars | MIKEPELLE | Recording Techniques | 32 | 09-05-2007 12:30 |
| Layering/Double tracking guitars | legionserial | Guitars and Basses | 5 | 10-31-2006 10:18 |
| tips for acoustic electric guitars | gusfinley | Guitars and Basses | 8 | 02-16-2006 21:37 |
| Layering and Mixing Guitars !!!!!!! | halo206 | Recording Techniques | 14 | 12-16-2004 10:52 |
| Need tips on layering guitar sounds. | VirtualSamana | Guitars and Basses | 8 | 10-21-2001 23:40 |
